Caliper Paints
I would highly recommend a product made by G2. The G2 Caliper Paint is a special paint designed for brake calipers to resist brake dust, high heat, and will not chip.
You have a few choices of spray to paint on paint products. Caliper paint is sold in a kit. Cost under $50.00 to $60.00. A bright red is available.
As mentioned, Rustoleum brand sells a Caliper paint. Duplicolor also sells a paint kit. I "do not" suggest a spray on application.
#1 Choice): G2 Caliper Paint Kit......Category
#2 Choice): Duplicolor Caliper Paint Kit.....Dupli-Color BCP400 - Brake Caliper Paint Kit | O'Reilly Auto Parts
With proper cleaning for adhesion, you can obtain a professional look as a DIY project.
I highly suggest and recommend a "brush on" vs "spray on" application. There are many YouTube videos that will provide a basic idea of how you should apply the "brush on" products.
Best to you on your project.
Richard in New Mexico
Panthro (06-01-2017)
I've had mine done with the duplicolour (XF over metal) and the G2 (XKR over powdercoat). I didnt do either myself, I had the tyre place do it because it was easier for them to put the car on the hoist and get the wheels off.
To tell you the truth, I wasnt 100% happy with either - I think powdercoating would give a much better result. But I couldnt get the prep that comes with the G2 product because of restrictions with overseas products, maybe that would have made a difference. And I am not very handy...
I used Rust-Oleum Hammered Silver #7213 for a natural OEM look. No extensive prep or primer required.
Unless you have high performance habits your brake calipers will never get hot enough to hurt the paint and a wide range of colors are avail from Rust-Oleum and you save a boat load of cash.
Big Otter (03-08-2017)
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/138122d1477945293-portfolio-alcon-brakes-installation-question-img_0152.jpg)
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/137999d1477591982-portfolio-alcon-brakes-installation-question-img_0133.jpg)
Well done! I love it. My favorite color for calipers. What did you use for paint? Did you spray for brush? IMO they really stand out and look fabulous. Nice rims too. Are they HRE or knock-offs? Your car looks great.
jahummer (02-14-2017)
Thank you! Probably would have stayed with red if the GT and F-Type carbon kits hadn't been optioned. The yellow works VERY well and is brighter than red. The paint is sprayed on with a very small HPLV gun using several layers of multi part high temp catalyst urethane with additional multiple coats of clear for a super high gloss wet glass look and ultra durable scratch and chip resistant finish. So far brake dust and heat have had no ill effect. The wheels are lightweight alloys custom drilled, offset and powder coated similar to the P101 Max had ok his XKR. In fact I was interested in his wheels but someone else got them.
