Call me crazy... flood XKR...Is it possible?
#61
Thanks, I'm looking at a 2011 donor now at a slavage yard but don't know as of yet what they will ask. When and if I get a donor then things should speed up quite readily! So here's to fingers crossed and that beautiful car seeing the road again!🍻
#62
Are you certain that the salvage donor car isn't flood damaged?
Cee Jay (03-08-2023)
#63
yes it's been damaged but runs and drives. So far I've learned a lot but mostly if you are going to do a flood Jag, have a donor available. Even a low flood (6 inches up on door) could be a bear. But i think it is still going to work out once i get a donor.
#65
It really has been a learning adventure. Im not begrudging it at all. Im actually impressed eith the build quality. I may not say the same this time nect year...but for now it going almost as planned
#66
#67
@GoFaster how about an update for us?
#68
This is a wild ride, hoping you're able to pull it off! One thing I didn't see anyone mention here (maybe I missed it) but in addition to the engine and trans fluids, don't forget to take care of the diff fluid. Water can work its way past the seals if it is submerged for long periods of time. Land Rover actually recommends that you change your diff fluid more frequently if you're doing a lot of water crossings.
#69
04xtypeguy (04-17-2023)
#71
True but the vents are on up high by engine so if the vents are sucking in water, you have bigger things to worry about. If a diff sits submerged for any extended period of time or you do a lot of ford crossings (like in rural areas in the UK) water can work it's way into the diff housing via the seals. It's not something a lot of people think about when it comes to cars and standing water.
#72
True but the vents are on up high by engine so if the vents are sucking in water, you have bigger things to worry about. If a diff sits submerged for any period of time or you do a lot of ford crossings (like in rural areas in the UK) water works it's way into the diff housing via the seals. It's not something a lot of people think about when it comes to cars and standing water.
#73
https://rimmerbros.com/ItemList--Tra...Fluid--m-15804
#74
GoFaster, you're brave. I don't mind mechanical but salt water soaked cars are a different challenge. If anyone is inspired by this article and wants to "jump into the pool", there's an 28k mi XKR on Bring A Trailer that's obviously been submerged in salt water. The car looks great but the heavily rusted and encrusted undercarriage is a clue. Pan has many scrapes. Almost like it was dragged over something. Leaves somehow stuck to the digital display panel. It's up to 7,500. Be interesting to see what it sells for.
#75
I'm sure many here visit BaT. The "sea special" 08 XKR was bid to 19k yesterday. Seller (car dealer) said reserve wasn't met. Looked great from the outside but undercarriage pictures showed extensive rust. One big clue was the digital display panel w/ leaves somehow attached or inside. Only visible info was the odometer (partially). Seller said that "many Jags come thru our shop w/ similar display problems". Yeah right.
#76
GoFaster,
Hope that you are aware that your FSJB and RSJB are specific to 2012 and up. Difference that I am aware: FSJB specific to headlights, RSJB back-up camera.
The salt water will attack unprotected aluminum such as bumpers. A nice 2012+ crash vehicle woul be a good move,
However, I would recommend that you restore the crash vehicle using the flood vehicle as your "parts" car. Much, much easier.
As a bonus, you could consider a convertible as your project car!![Icon Biggrin](https://www.jaguarforums.com/forum/images/smilies/icon_biggrin.gif)
#77
#78
#79
#80
UPDATE:
During my search for a donor car (which can get expensive quickly) I ran across a 59k mile XKR with a seized engine. So my project car with 22k miles just became a donor car! Maybe as time goes on I can find a wrecked car and bring back another XKR with parts from the donor car.
wj
