Cam Chain Tenshioner Replacement
A small but very important issue respecting cam tensioner replacement. The spring that loads the tensioner is always replaced. This spring comes loaded in a little assembly which has the spring collapsed and under tension..
What is not apparent to some mechanics is that the spring must be "unloaded" after it is installed. There is a little holding pin on the spring assembly that must be removed.
The video below shows how that pin is installed and removed. I started the video right where they explain unlocking the tensioner, but the whole video is really good. The land rover in the video is using the same engine that's in the 5.0 supercharged XKRs. It gives a pretty good overview of what is involved in repairing the engine after the timing chain jumps a tooth.
The following 2 users liked this post by Reverend Sam:
gkubrak (06-07-2020),
Queen and Country (06-07-2020)
V7Sport (06-07-2020)
Received 2,646 Likes
The following 3 users liked this post by NBCat:
GordoCatCar
08-02-2008 01:02 PM
