Cam phaser troubles anyone?
Old 09-30-2011, 12:19 AM
TRidder's Avatar
Question Cam phaser troubles anyone?
I have an '07 XKR Coupe that began to develop a very disturbing noise at start up about 2 months ago. Can't really describe it, but it sounds terrible! Only does it at cold start ups, if you turn the car off and then restart within the next hour or so, it did not make the noise.
Anyway, I take it to my buddy who is the GM of a Ford dealership. He correctly diagnosed that the problem has something to do with the camshaft phasers. He sent it to the local Jag dealership and they seem to be dragging their feet on the repair. He says its a pretty big job - listed at something like 30 hours or better. He also told me that there was a Jaguar service bulletin about this problem.
My baby has just over 41,000 miles on it. Fortunately I had purchased a 5 year 60,000 miles extended warranty from Zurich just after it went off factory warranty!!
Anyone else had this issue? And if so, how did it turn out? Car good as new?
Thanks!
Old 09-30-2011, 12:33 PM
rscultho's Avatar
Oh great...another Jaguar CAM issue????
The last episode they had with the timing tensioners was more than enough.
Old 09-30-2011, 01:45 PM
davewhitt's Avatar
are you talking about the vvt unit ,because if it is that don't you get a check light on ,
Old 09-30-2011, 01:48 PM
davewhitt's Avatar
XK303-01 - Removal of Smart Key From Docking Station
JTB00237 - Non-Start Assistance Guide
JTB00198v3 - Oil Leak Rear Of Engine
JTB00155v2 - Diagnostic Trouble Code (DTC) with P2119 Stored
JTB00136v2 - Thread Repair for Aluminium Components AJV8 and AJV6 Engines
JTB00111 - Revised engine Replacement Procedure XK - XJ
JTB00107 - Restricted Performance With DTC P061A Stored
JTB00046 - Engine Detonation (Pinking/Pinging)
JTB00045v4 - FEAD/Supercharger Drive Belt Noise
JTB00033 - Smart Key Component Replacement
JTB00022 - Vehicle Goes Into Limp-Home Mode With Diagnostic Trouble Code (DTC) P2135 Stored
JTB00004 - Malfunction Indicator Lamp (MIL) 'ON' with Diagnostic Trouble Code (DTC) P0172/P0175 Stored
i can't find a tsb about the vvt
magmedia
08-15-2019 08:54 PM
LnrB
10-13-2015 12:45 AM
speacock
10-03-2015 11:15 AM
dpappyp
09-29-2015 01:28 PM
Quick Reply: Cam phaser troubles anyone?
