I have 2007 xkr x150 4.2 convertible, history of the car is unknown except it had accident and front was dameged. Car runs fine, no warnings on the dash, but obd diagnostic shows some fault's.
after clearing codes all comes back.
tested all wirings everything is good, communication tested with oscilloscope all ok HCAN MCAN LIN..
except: Fault with amplifier b - I find 2 cutted off big blue cables (with 9 wires inside each) these goes from passenger footwell (were are amplifier) to the trunk. I think here was another amplifier..
original amplifier working. SDD shows green tick. But all wires from the speaker's are cutted off then connected with amplifier and insulated with black tape. Steering column lock fault: here is no module, steering column have something like original cover screwed with bolt were this module must to be. Speed control module: all faults light's up when car not started, just ignition is on.
I think here are swapped some modules or something like that, because CCF shows some mismatch's.
I tried change some configuration's, but without success..
Any advice would be great.
Is your check engine light on? Are you experiencing drivability issues? These sound like intermittent nuisance codes and as mentioned above, the battery should be checked.
Looks like some aftermarket audio work has been done...poorly.
Do the audio and speed control buttons on the steering wheel work? (if equipped)
Does the infotainment system function correctly?
I did not notice any driving problems, no check engine on the dash. the battery looks like new. but not original. i don't think it's a battery problem because all the tests and obd scans are done with a battery charger that lasts up to 180a 13.3v.
and yesterday, I tried with the engine running - same faults.
only noticed that after clearing the fault codes the speed limiter works, but after a couple of minutes when the fault "invalid data received from speed contol module" occurs in obd, then on the dash "speed limiter not available" lights up, and speed limiter doesn't work.
another think I noticed is that when i try to connect to any module in the MOST network line via obd, it looks like a big power consumption shock. at that moment, engine damping is felt. Tomorrow I will test it deeper..
all steering wheel buttons working perfectly, audio and speed control and gear shifter's too.. I did not notice any issues with infotainment system (maybe not tried all functions). Will check this tomorrow..
In ccf configuration's file audio system is Premium sound 4x70w 12 speaker's, but in real car have only 8. When I change to "high performance 4x40w 8 speaker's" then no audio at all and lcd won't boot up, shows only jaguar logo.
I highly suspect those 9 wire cables are OEM and the previous work done, just By passed the existing wiring, not knowing how it would effect things.
Thankfully they knew enough to keep the steering wheel buttons functioning. Sorry, I can't help more...but I would find the wiring diagrams and find out
where the Blue harnesses run and where they connected originally. Or if you can live with it and it doesn't cause issues (se la vee).
Today I figured out what is causing this fault "U0405-8f Invalid data received from speed control". This fault was caused by my launch obd scanner. this fault does not occur during SDD diagnostics and the speed limiter works fine, but if I click "clear all DTC's" with Launch, the speed limiter no longer works.
And B1026-13 Steering column lock - open circuit. I Found a document XK419002NASF.pdf and how I understand this is just module software glitch ( false fault code) or something like that..
You might be able to reset that wonky module by doing a Hard Reset. That will discharge the capacitors in certain control modules by grounding them, which returns them to their original defaults. Follow the steps in the above link.
