Can we talk about the 5.0L water pump
My 2012 XKR is B46488 and my 2013 XKR-S is B49722. It appears BOTH are not the newest water pumps, however the R-S has not been super-ceded. What should we do when the water pump is super-ceded??!? Should I ask it to be replaced with the newer water pump under warranty?
Ryan
Ryan
My 2012 XKR is B46488 and my 2013 XKR-S is B49722. It appears BOTH are not the newest water pumps, however the R-S has not been super-ceded. What should we do when the water pump i super-ceded??!? Should be ask it to be replaced with the newer water pump under warranty?
Ryan
Ryan
They are coming out with a new water pump this Sept for the XK?! I wonder since the engine is the same exact one in the F-Type R if it's for that....wonder if F-Type will fit on XK.
I am looking at the workshop manual... I can not tell if the water pump component is inside the engine in that picture/or located outside in a more accessible area... Being such a car novice (however extreme XK lover nonetheless) and having no idea of the internal working of a car....does anybody know how easy it is to replace the water pump (for purposes of determining if the dealer is going to screw me with so called labor hours)? Terry's Jag parts has a newer than my current water pump available for 250 plus shipping (Not the newest however!).
The water pump is located outside the engine and bolts on. If you're going to replace your pump and you have no immediate need to do so I would suggest you wait to get the latest available pump. Their must be a reason why another revised pump is available.
Lothar52 (06-29-2014)
Ryan:
I am not sure that I would take the approach to start changing out parts on your car, in the fear that something might happen to your car, or that upgraded parts might be available.
As I have stated in the past, the more one reads these forum posts, the more the driver/owner can get a sense of fear, that something might go wrong with their respective Jaguar vehicle.
Many times, because of the style of the forums we are hearing the horror stories that raise concern for all of us. I would take the approach that every car owner, whether Jaguar, Porsche, Aston Martin, Lambo, Ferrari etc, that the owner take a pro-active approach to monitoring/inspecting their vehicles. That is on a regular basis, lift the hood, try to look for potential problems. Inspect tires, wheels, interior, exterior, etc. You will get to learn and know your premium car much better. You don't have to be a car/mechancial guru to do this. Everyday in life is a learning experience.
These are premium vehicles that we have and the Jaguar brand is known well for the so called electrical gremlins. In my service manual there is a picture of all the electrical connectors, modules, sensors on my 2009 XKR. I am sure they are not much different in the newer models. When I saw the photo I got scared and thought, no wonder there can be electrical problems, as the XKR is an electrical wonder. There are so many, I was amazed.
As for the hardcore parts like water pumps, fuel pumps, internal parts of the engine, most of the time, we as car owners can not possibly detect that we will have a failure of some kind until it occurs. So why lose sleep or sweat the possibility of a failure. In most cases they just occur, then we need to find a resolve or have the part repaired or replaced.
Just enjoy the car. You have 2 beautiful Jaguars and I am sure that they both get limited mileage, and most important they are under warranty. Why worry about something that might happen....and never does.
In the latest mess that we have read about BrooklynChris and his water pump fiasco, the bottom line is, the car was under warranty and he is getting a new engine. In a few months, time will pass and he won't even think about what happened in the past. His personal situation however does bode well to own a car, no matter what brand under a factory or extended warranty. That is why I highly suggest to anyone that is considering a Jaguar of an earlier model to make sure they conduct mechancial inspections and do their due diligence before laying down the cash for the car. Especially when the vehicle is out of warranty.
Point taken Rich! I just wish we all understood whey some many different part numbers...what did they upgrade on these pumps? who knows...
#30
#31
#32
Not to get yourself overly concerned, if you have a warranty, it might be a good idea to go in and have it checked as soon as you can. Smelling coolant is not the norm unless you have a very sensitive nose! Our water pumps can fail with low miles. My friend replaced his at 20,000 miles on his 2010. Good luck and let us know how you make out.
Lothar52 (07-04-2014)
Lothar52 (07-03-2014)
#36
Twice in 24K is BAD. Now, I will worry about any longish trip in all my Jaguars. I already got the TorquePro app just because of this issue.
#37
That is quite disheartening. Just shows that the water pump replacement has not been updated and even if it has the problem is not resolved.
#38
#39
My local Jaguar service manager told me that his techs will always check the 2010 XK+ when in service (for anything) for coolant stains or water pump leakage and will replace if observed.
#40
