Can we talk about the 5.0L water pump
#41
I spoke with my local Jaguar shop foreman about the water pump issues and I was somewhat disappointed when he informed me that Jaguar had issued a bulletin that some water pump leakage or staining is "normal" on our cars and does not necessarily warrant a replacement if under warranty. It's up to the dealership to decide if it is leaking badly enough to get replaced. Yes there are 3 updates on the water pumps so if you are getting yours replaced #3 is the charm. I was told that 4 or 5 engines have been replaced due to overheating which really isn't a lot for a dealership, but I wouldn't want to be one of those poor souls! Go figure!
#42
This grates on me to no end!
#43
#45
#46
Should not be a big job. I would say about 2-2.5 hours shop time plus the cost of the new pump. For out of warranty cars it would be money well spent. For in warranty cars, go to your dealer before warranty runs out and insist on having it replaced under warranty--it is your car and your engine--for proven defective design. It is only a matter of time before the pump goes and you don't want to loose your engine with it out of warranty! You had all 4 of your headlights replaced under warranty. The water pump is less expensive and much more critical.
#47
#48
#49
FYI: the 4.0 L (XK8) 3rd generation Jaguar W/P still has a plastic impeller. Changed my wife's 2000 just for fun!
Very simple task; but nothing wrong with old one.............
I believe some after market (4.0L) impellers are Al.
Don't understand why Jaguar has to try 3 times to get it right, still!!
Cheers, Adrian
Cheers, Adrian
#50
Had my original water pump replaced a year and half ago at 48,000 miles. it was leaking everywhere and was obviously bad. Just replaced that pump myself at 80,000 miles, after smelling coolant and having my low coolant light go off twice. Dealer wanted $275 for the pump assembly or $850 to replace and install it. I ended up buying it from Brian Wilson at jaguarpartscheap.com. Brian was super knowledgeable and made sure I had every thing I need for the job. The pump I bought was part# C2Z21781 and that looks to be the same pump that was installed a year and a half ago (identical markings and numbers on the pump). The pump comes with the gaskets but I had to order the O-ring and outlet tube as they are not included with the pump.
The pump is made by Ford Motor Co and is a two piece component with an internal gasket. Never seen anything like it. The internal gasket is what failed on my pump. My guess is that is a very common issue with this pump. The newest pump is also available at jaguarpartscheap but it is $453. Had I read this post and known the pump I was getting was the same as the previous I may have gone for the more expensive one, but I wasn't sure the old one was the same until it was out, and I didn't want to be without a car for several days.
Replacing the pump isn't difficult for the average DIY mechanic. A few tips...the tension bar can be can be slacked by inserting a 3/8" socket wrench into the square hole in the bottom of it. I used a cheater bar with the wrench which made it a simple task. You will need to take the tension bar off after you get the belt loose, but it's not difficult. There is a hard plastic tube coming out of the front of the water pump. You have to push on the plastic ring that is up against the pump while you pull the tube out of the pump. Tube comes straight out, nothing fancy. After the water pump is bolted on (4 bolts), put some coolant back in through the top of the water pump before you re-connect the hose going into the water pump. It's the only way to make sure you don't have air pockets in the engine as the only other place to add coolant is the excess reservoir.
Last edited by Mccainszoo; 07-11-2014 at 10:18 PM. Reason: 2010 XF Premium Portfolio 5.0
#51
Do you own an XK or an XF?
#53
#54
I recently had the water pump replaced on my 2010 XKR (under my 12 month used car warranty) after I took it to the dealership as I'd had a "Low Coolant" warning on the screen, and despite topping up the coolant level continued to require topping up.
However a few weeks later, after a long weekend drive totalling 700 miles, the warning re-occurred and the fluid level level continued to reduce below Min level. I took it back to the dealership and they showed me the amount of fluid leakage into the engine tray. I've now had to leave it at their workshop for a few days while they investigate.
What could this be? They told me they can't diagnose without stripping part of the engine to have clear access.
The job will be under my warranty but I'm curious what the possible causes could be?
David
David
#55
David
David
DLux (08-30-2014)
#56
I had to replace my Outer Tube after replacing the water pump. I now believe the Outer Tube could have been the problem all along. It is a plastic piece that carries coolant from the top of the engine (behind the water pump but under the intake manifold) to the hoses to the right of the water pump as you are facing the car. The Outer Tube is a plastic piece that looks like it is two piece that are put together when it is manufactured. Mine sprung a small leak right in the middle of the seam. The leak was behind the water pump, so I couldn't see it until I had the manifold raised and did a pressure test on the coolant system.
Must be a common problem, the local Nashville Jag dealer had it in stock, and they don't carry much inventory. I saw on another post where Brutal had replaced a couple of them in one day. Part was less then $30, and it gave me a chance to clean my intake valves up a bit.
#57
Problem solved! I've just got my XKR back from the Jaguar dealership garage and the coolant leak was due to a faulty new water pump which had only been fitted a few weeks earlier! Apparently it had fractured. They have now replaced it but presumably with the same type of pump so fingers crossed that new one is not faulty. So pleased to get my car back after 4 days absence.
Thanks for all the suggestions.
David
David
#58
David
David
#59
#60
Let us know what you find out Ross... I'm antsy about this topic I want a pump that does it's job right all the time!!
