Can we talk about the 5.0L water pump
Old 09-04-2014, 12:58 AM
bocatrip's Avatar
As there have already been 3 updated waterpumps, are we talking about a 4th?
  #62
Old 09-11-2014, 07:22 PM
Lothar52's Avatar
So we are well into September and my Jaguar Dealership and I have not heard anything about an updated water pump. Anyone else know anything?!?!?
  #63
Old 09-13-2014, 10:35 AM
Lothar52's Avatar
Still no news? Anyone know anyone that knows anyone that would have info???
  #64
Old 09-13-2014, 06:52 PM
Rahtok's Avatar
Went by the Bellevue, WA Jag dealer today to get some parts, and there was a 2010 XK up in the shop in the midst of an engine swap due to water pump failure. Tech said the guy must've driven it a while because it had coolant in the oil due to overheat.
<shrugs> Another data point. What would be interesting is to have this correlated with XJs and Range Rovers using the 5L motor -- are they having failures too? If not, maybe we have a problem unique to the packaging in the XKs.
  #65
Old 09-13-2014, 08:06 PM
DGL's Avatar
DGL
DGL is online now
This defective water pump problem must be costing Jaguar a little money. Is Jaguar using the same water pump in the F-type V8 S and R?
  #66
Old 09-13-2014, 11:23 PM
u102768's Avatar
Received 1,490 Likes on 908 Posts
C2Z28248 still seems to be the current part number and it is listed for the XK, XF, XJ and F-Type.
  #67
Old 09-14-2014, 09:21 AM
Mccainszoo's Avatar
The fix for the water pump may be the new way the coolant is routed out of the water pump. I believe it allows for better flow and less back pressure. The two part numbers for the new hoses are AJ813565 and C2Z28467.
  #68
Old 09-14-2014, 10:00 AM
Rahtok's Avatar
Well, if the failures don't cross over into other models or Land Rover... then yeah, it's got to be something specific to the XK implementation. I suppose hoses would make sense then.
  #69
Old 09-21-2014, 02:31 AM
Lothar52's Avatar
So is that the upgrade?!? Hoses?!? Not really a new water pump or ?
  #70
Old 09-21-2014, 11:44 AM
bocatrip's Avatar
I check my coolant reservoir level once a month for at least a minimum precautionary measure.
  #71
Old 09-21-2014, 01:47 PM
Ngarara's Avatar
Received 1,126 Likes on 797 Posts
If the problem is caused by excess back-pressure, and the new hoses reduce that, then that may be the fix.
Lothar52 (10-02-2014)
  #72
Old 10-02-2014, 05:44 PM
Lothar52's Avatar
I had my local jaguar dealership look up the numbers given by the poster that listed hoses and tubes saying that was the fix:
AJ813565 is a HOSE description listed at a price of 36.82
C2Z28467 is a TUBE description listed at a price of 36.57
Dealer prices.
Now then nobody I know knows for sure if this is exactly the fix?!? Is the latest water pump required to use these tubes/hoses??? Is it advised to update/replace all parts at once?? It is advised to do so if you have not had a low coolant warning but yet your water pump number, as mine as, has been superceded!?!?
Loth
  #73
Old 10-02-2014, 06:24 PM
Lothar52's Avatar
this is of MAXIMUM IMPORTANCE... was just told today by dealership he had a few more pump failures... ITS JUST A MATTER OF TIME!! If there is a fix we need to make sure we know exactly what to request and GET IT DONE!!
  #74
Old 10-02-2014, 09:06 PM
bocatrip's Avatar
Even if this information is correct, the replacement is going to be entirely at the owner's cost. This certainly will not be covered under any factory or extended warranty unless there is a failure of the part.
  #75
Old 10-03-2014, 10:49 AM
Rahtok's Avatar
I just had my local dealer look these up as I'm up for scheduled maintenance. Parts guy says that these are for normally aspirated 5.0L for a VIN range after mine (mine is a VERY early 10). Does that mean we have different piping immidiately after the water pump between XK and XKRs?
Loth
  #76
Old 10-03-2014, 11:44 AM
Rahtok's Avatar
So... XK pumps different from XKRs. We should start tracking failures for each to see where the design flaw is.
From the parts guy himself:
THE #’S YOU SUPPLIED ARE FOR THE WATER RAIL AND T-STAT, SUPERCHARGED CARS HAVE AN AUX PUMP AND RADIATOR FOR THE SUPERCHARGER, THE WATER PUMPS FOR THE ENGINE ARE A DIFFERENT PUMP.
R** ******
Bellevue Jaguar,Land Rover
Bentley, Rolls Royce, Lamborghini
Parts Department
Muddydog (10-06-2014)
  #77
Old 10-03-2014, 04:06 PM
CleverName's Avatar
Wow, A very long read, and disappointing to hear of a cooling system failing on the new 5.0 design. Odd the 4.2 has not gotten a bad pump reputation (Just thermostat).
So my question is if the internal seal is allowing fluids to weep by and damage a bearing, could you switch to waterless coolant and prevent the weepage?
My thought is without pressure (waterless does not pressurize the cooling system), the seal should hold far longer.
Might be worth review for this scarey problem.
Food for thought.
Vince
  #78
Old 10-03-2014, 06:12 PM
bocatrip's Avatar
I'm not 100% certain, but there is a chance that my coolant level in the reservoir is ever so slightly lower after 2500 miles of driving. I'm not totally certain how high it was topped off to begin with, but now If anything, we are talking about a few ounces. I know if it gets any lower. It still reads full on the side when cold. If so, I will address my local dealer before bringing it in. They don't replace water pumps unless there is a significant leak. I'll try both of my nearest dealerships to see who has the more favorable response.
  #79
Old 10-03-2014, 10:57 PM
Lothar52's Avatar
Holy crap... Part isn't ever for the XKR... Ugh!
  #80
Old 10-04-2014, 12:56 AM
Rahtok's Avatar
Looks like the issues may be with the normally aspirated one, not the XKR. I know the one I saw at the dealer a couple weeks ago was an XK, and not an R.
Quick Reply: Can we talk about the 5.0L water pump
