Can you change the analog clock in the display between the tach and speedo?
You change the analog clock by changing the digital clock in the infotainment center. On the right hand side of the touch screen is a series of bars. Each on cares a title such as, climate control, telephone, navigation, audio, etc. I cannot remember the name at the bottom. But that is the bar you want to touch. It will provide you with a number of options, one which, is either clock or time adjust. adjust the time by touching the bar; a screen will come up giving you the options you need. Make your adjustment there and be sure to press the set clock button on the lower left. Your analog clock will now be adjusted as well as the digital clock in the infotainment screen.
LoudHogRider (12-08-2016)
Ralph, I think he wants the display to provide a picture other than the clock. I don't think Jaguar offers a choice of display pictures that the owner can choose from. I guess you could let some air out of one of the tires, then the TPMS would display instead of the clock.
