Car battery is always empty
Old 09-02-2018, 08:01 AM
Patrick Wong's Avatar
Turn on the cabin lights and see if they turn on while the meter is connected as in the photos. If they turn on, what is the meter reading now?
  #42
Old 09-02-2018, 08:05 AM
Jagstefano's Avatar
when the cable is disconnected there is no power trough the car so nothings is working for my feeling
the connection is ok wit the meter as showed on the picture?
  #43
Old 09-02-2018, 08:32 AM
Ranchero50's Avatar
Lightbulb Use common sense.
If the lamps light with the battery hooked directly but do not light with the meter in AMP mode connected between the battery terminal and the wire then your meter is no good...
  #44
Old 09-02-2018, 10:30 AM
Cee Jay's Avatar
Received 5,360 Likes on 3,174 Posts
Yeah, the fuse in your meter is blown. Open the back of the meter and replace it.
  #45
Old 09-02-2018, 10:36 AM
Cee Jay's Avatar
ALSO, one cannot merely disconnect the battery cable and then connect the meter in series, as when the car first detects voltage all sorts of things turn on. That would be in excess of the 10 Amps and immediately blow the fuse.
I spent several weeks off and on trying to find a drain in my F150 and I learned a lot of things doing it.
To do this correctly, you must hook a jumper between the cable and the battery post. Position your doors and boot lid switches/latches to the CLOSED position so the lights and sensors are OFF. Allow about 30 minutes or so for everything to shut down. THEN, you can FIRST hook the meter leads between the battery cable and the battery post and THEN disconnect the jumper lead. That way, the modules won't reset and turn on as there has been a constant voltage.
The following 4 users liked this post by Cee Jay:
Patrick Wong (09-16-2018), PatrickO (11-26-2020), Ranchero50 (09-02-2018), u102768 (09-02-2018)
  #46
Old 09-12-2018, 08:28 AM
pwpacp's Avatar
That should be a "best practice" that we should all take note of when checking current draw!
Cee Jay (09-12-2018)
  #47
Old 09-16-2018, 05:53 PM
ALSO, one cannot merely disconnect the battery cable and then connect the meter in series, as when the car first detects voltage all sorts of things turn on. That would be in excess of the 10 Amps and immediately blow the fuse...
Yes, this would be true when using a regular digital multimeter with a 10A current limiting fuse.
For those who are sufficiently interested in measuring high current to make this meter worthwhile, this is what I use for measuring up to 200A AC and DC current, without having to disconnect any leads. The resolution is only to 0.1, however, so this is not good for measuring very low currents or voltages:
https://www.fluke-direct.com/product...SABEgKDk_D_BwE
  #48
Old 12-26-2018, 01:18 AM
Jagstefano's Avatar
Problem is solved. I changed the battery . the battery didn't charged well that's why its broken.
  #49
Old 12-26-2018, 04:25 AM
MarkyUK's Avatar
And you've replaced it with exactly the same battery with the same specs?
I have a tracker fitted to my car (which advises me of battery voltage when I use the app) and notice that drain is between approx .03-0.5V for each 24hrs it's left undriven, So based on it sitting at 12.70V now worst case it would drop below 12V in 2 weeks, which sounds about right. Natch am not going to test this out (unless going on holiday)
When I plug it into a CTEK overnight it gets up close to 14v, but once driven this drops quickly to around 12.8v
v1rok
01-29-2017 07:47 PM
vincent661983
12-13-2013 04:55 AM
keestanis
04-07-2013 02:45 PM
MySTypeAteMyRX7
12-18-2012 02:43 PM
Quick Reply: Car battery is always empty
