Car beeps as I walk away from it?
If this system works like others the inside handle should move when the button on the outside handle or the fob is pressed. There is a linkage rod that activates the latch. I believe there is also a sensor on the solenoid that tells the system that the door is locked or unlocked. Something in that area in that door is not functioning . I would pull the door card and watch it function.
chazaroo (09-26-2017)
#31
I have this issue on my passenger door,
I have to close the door with twice the force as the drivers door
or the window will not tuck away under the body, and hence
it will not lock properly.
The car beeps twice letting me know it did not lock.
Any suggestions on fixing this?
I feel like it may be an alignment issue on the switch in the door.
#32
