Car key battery drain
The key still works, but I need to be very close to the car to operate de key and after a while the car will signal to change the battery
I don't have problems with the car battery draining.
This is strange, as I have the same problem with both key fobs.
Maybe IKEA battery pack is not so good after all...
http://www.ikea.com/us/en/images/pro...E426170_S4.JPG
I think you've solved the problem. Get some quality batteries, and forget those 'no name' multi-packs (I've tried them in the past, and most of the batteries are already dead).
Battery Drain and key fob
I've had that issue and I assume it was because my garage is close enough to where I kept the fob that they "stayed in touch". Now, I can't walk to the garage and start the car with the fob in the house, but the fob drained none the less. Two different cars, so not the fob or the battery. I now keep the fob in a closed metal cookie tin. No more issues.
Nosferatu,
You're in Russia and I know nothing about how CR2032 batteries are marketed there. In the USA, some, but not all, of those batteries are labeled with a shelf life date. I used to buy those batteries on eBay and Amazon because they were really cheap but no longer do so because they didn't last. I now buy them only from local stores so I can read the date and be sure to buy fresh inventory. I suspect that the IKEA batteries didn't last because they were old inventory.
Stuart
P.S. I recommend keeping a spare CR2032 battery in your glove box.
Stuart
shadow88
04-04-2016 05:01 PM
