Car is in winter storage!
Old 10-31-2017, 07:18 AM
peterv8's Avatar
Default Car is in winter storage!
Car is now off the road for winter, will be back on the roads in april-may.
Will lower the car and do some maintenance meanwhile.
Had problems with mice on my MG a couple of years ago but solved that when I got a sciccorlift!:-D
Old 10-31-2017, 08:48 AM
110reef's Avatar
What is winter?
davchr (10-31-2017)
Old 10-31-2017, 09:49 AM
SinF's Avatar
Received 2,141 Likes on 1,461 Posts
Dryer sheets, moth *****, pepper spray all work.
The following 2 users liked this post by SinF:
kj07xk (10-31-2017), Rick'sJag (11-22-2017)
Old 10-31-2017, 10:28 AM
Cee Jay's Avatar
Received 5,453 Likes on 3,215 Posts
What are "mice"?
Old 10-31-2017, 11:08 AM
peterv8's Avatar
Originally Posted by 110reef
What is winter?
Salt! :-)
Queen and Country (10-31-2017)
Old 10-31-2017, 02:05 PM
Sean W's Avatar
Received 4,258 Likes on 2,379 Posts
that can't be good for the suspension long term. Plastic paint tarp spread over the lowered lift to prevent moisture evaporates from concrete. scatter moth ***** around the tarp. Steel wool or shop rags in the exhaust and dryer sheets in the engine bay and interior. All will keep mice at bay.
The following 2 users liked this post by Sean W:
Old 10-31-2017, 02:19 PM
Cee Jay's Avatar
Agreed with that ^^^^^^^^^^^^
Ground moisture, especially when the car is covered, can wreak absolute HAVOC with an engine bay especially, all that wetness soaks up from the ground and is trapped beneath the cover. Lots of nice steel and aluminum parts covered in wet for months on end...
The following 3 users liked this post by Cee Jay:
kj07xk (10-31-2017), Rick'sJag (11-22-2017), Sean W (10-31-2017)
Old 10-31-2017, 02:22 PM
Received 2,655 Likes on 1,825 Posts
You are stressing the suspension bushes with the wheels off the ground for an extended period of time.
The following 2 users liked this post by NBCat:
davchr (10-31-2017), Sean W (10-31-2017)
Old 10-31-2017, 02:28 PM
Cee Jay's Avatar
Use the scissor to lift, then put four jack stands under the lower arms.
The following 2 users liked this post by Cee Jay:
Old 10-31-2017, 03:14 PM
Knomad's Avatar
Our car was put away last weekend. It sits on a rubber mat in the garage with a container of mothballs under the engine compartment. Inside are a number of dryer sheets. There is marine grade stabilizer in the gas, then the car is run for 5 to 10 minutes to distribute the stabilized gas throughout the fuel system. I put a extra few pounds of air in the tires but do not put the car up on jacks. Of course, the is also a battery maintainer connected. Last but not least is the cover.
The following 2 users liked this post by Knomad:
kj07xk (10-31-2017), Sean W (10-31-2017)
Old 10-31-2017, 04:12 PM
kj07xk's Avatar
Received 2,025 Likes on 1,355 Posts
Don't think I could stand the smell of mothballs in the garage, but adding a few dryer sheets to my winter storage sounds like a simple prevention.
Old 10-31-2017, 04:39 PM
Don-T's Avatar
Originally Posted by Cee Jay
What are "mice"?
They look like little prairie dogs with long tails.
Old 10-31-2017, 06:03 PM
Cee Jay's Avatar
Like this???? Can't see the tail though.......
Old 10-31-2017, 07:42 PM
Ranchero50's Avatar
Not a big fan of high centering the chassis for storage. I think that's a quick route to tearing the suspension boots. Mice are like ninja's. The best defense for a car is have someplace better for them to live vs. the car.
My '68 Fairlane sits on a dirt floor in my lower shed that has water run through it on occasion. Car's been resting there the past 20 years without suffering. I usually keep a cotton cover over it and maybe some old blankets so the feral cats don't scratch it up.
Old 10-31-2017, 08:48 PM
AllblueACR's Avatar
Default Hibernation
Put mine to bed Sunday
Old 10-31-2017, 11:16 PM
davchr's Avatar
What is winter?
Around here that is when the snow birds show up.
Old 11-01-2017, 02:37 AM
peterv8's Avatar
I had my MG ZT V8 for 8 years(a modern car 2005) and on the scissorlift for 4 years with no problems to suspension nor did it rust or corrode from moisture. My garage is not heated but has insulation in the walls and is dry.
Old 11-01-2017, 04:15 AM
Aonsaithya's Avatar
Salt! :-)
The car has an aluminium unibody, so I don't think salt is that big an issue. Sure, some chassis bits are steel still, but they can be protected otherwise.
I'm driving mine through the winter, and nervously looking forward to my first rwd+snow experience.
Old 11-01-2017, 06:17 AM
peterv8's Avatar
Aluminum might be better but it corrodes, seen a few Xk's where the aluminum crackles the paint cause of corosion.
Take a look under an XK that has been driven year around where they use salt and look under a car that hasn't!:-)
My car hasn't been on winter roads and is totally rust free underneeth, it's absolutly mint condition for a 11 year old car!:-)
The following 2 users liked this post by peterv8:
Aonsaithya (12-09-2017), Sean W (12-09-2017)
Old 11-01-2017, 12:29 PM
flyc2c's Avatar
Just Googled "winter". Looks like it sucks.
The following 2 users liked this post by flyc2c:
110reef (11-01-2017), davchr (11-01-2017)
