CarPlay Solution
[QUOTE=Sean W;2579758]Agreed, it doesn't look OEM. There are other options.
This one if all you want is music:
Bovee WMA 1000 bluetooth device will work with you car to stream music. I will display your songs, uses steering wheel controls and no change to OEM appearance or function. This should work for the 07-09 models. I don't know about the 2010 onward (are the cables installed?)
I did install the Bovee 1000 on my 2011 and it works perfectly.
