Cat system failure/water pump issue?
Hello everyone, I have a quick question for you guys maybe someone has experienced these issues and can guide me. 2007 XKR got the “cat failure” message on the screen. Also yesturday it started with fans turning on as soon as I turn on the car. They are at full speed right from the start. And when I shut the car off they also run for about a minute after. Also, i got the “battery not charging” warning as well. All this the same day and at the same time. Any ideas or suggestions will help thanks
Definitely - suspect the battery first! It may seem contrary to common sense that a failing battery would start the fans going, but battery failure in these cars - and that means not only a battery at the end of its life, but a battery that has not been kept fully charged (and this can happen despite being used almost daily if the runs are short) - produces a great variety of electronic issues - warning lights, outside lights coming on, wipers moving, top not latching, touchscreen freezing, windows and seats not behaving...the list is very long. In virtually every case there is nothing wrong with the component. The problem is that the module which controls the component is not receiving full voltage - and bizarrely, this means that components you have not switched on, can become active.
So, the battery first. If it is more than 4-5 years old, replace it (and be aware that new batteries are NOT fully charged in most cases); the best advice for the XK models: obtain a CTEK battery maintainer and use it when the car is not actually in use. Photo of a resting XK (note the CTEK charger on the floor):
You didn't mention how old the battery is. Also while you have it at autozone have them do a Load Test also. That should give you an indication of the battery. I would say that at 11.58V your battery is bad. As mentioned it should be 12.6 volts at rest.
You should be ashamed of yourself that your garage is so much cleaner/neater than mine!
Maybe the alternator has failed. Pls start the car and measure the voltage while the engine is running to see if the voltage increases to 14.2V or more. If the voltage does not increase then the warning is valid.
Also, what is the odometer reading?
Ok so I checked the voltage with the car running. Shows 13.29. Does that mean the alternator is no good? And the car has 100,800 miles on it.
That isn't promising at all. Did you have on any lights, stereo, seat heat/steering wheel heat, stuff like that?
13.3 not great, but also far from good. Me, I'd turn on every power-draining thing in the car and try your test again. The more info, the better.
Again, doesn't seem promising so far.
It would be a good idea to follow the troubleshooting tree before deciding to replace the alternator. Good luck.
Received 1,975 Likes
Yes, check the cables. Another member, I think WhiteXKR, found he had a bad connection in the cable itself, between the wire and the connector. In his case, the wire/connector was ‘warm’ from the resistance due to the bad connection. He replaced the cable, all good. I don’t recall if it was the positive or negative cable, but check both for warmth.
Timothy
05-16-2012 07:14 PM
AntixSD
04-03-2010 07:40 AM
