Catalytic Converter INSANE PRICE FROM JAG
Hi, All.
I have a 2010 XK that has 11k miles on it (I don't drive it much). It was throwing a check engine light and the dealer is asking 4k to replace Catalytic Converters on the car! Insane, the car is only worth like 25k!
Anyone have any recommendations on what to do?
Thanks,
Joey
Thanks,
Joey
Isn't Jaguar Corporate still in MAHWAH????????????????????
Drive over to Corp and complain!!!
Just kidding. Ask around and see if anyone knows anyone that you could talk to. Somebody you know must know somebody that works there!!!!!
I used to stay at the RAMADA INN on Route 17 go there for training a decade ago.
bob
bob
if not . just get some magnaflow cats on line , (preferably high flow) about $200 each . and they have high flow all state legal as well.
and have them welded in at an exhaust shop or a trusted private workshop.
that way you will be upgrading the car from stock with a nice power increase,
at less than half the price you were quoted for stock bricks .
ralphwg (10-29-2016)
Joey,
I've moved your question from General Tech Help forum to XK/XKR forum.
What to do? Ask for a detailed explanation of the reasons they believe the Catalytic Converters need replacing. At the very least I'd expect to see the list of relevant codes, evidence they'd been cleared and had then reset.
Cats usually only fail as a result of wrong fuel, misfiring or physical damage.
If they are selling you a load bull, bring it to an indy shop. At least get a code print out from dealer and have them do a reset. See how long before it comes up again and what those codes are.
Aftermarket high flow cats are the way to go. I'd do an exhaust upgrade while you're at it. Unleash the beast!!
Like Triple-G says above a failure in the Catalytic Converter is rare but not unheard of in general. I have had 15 cars over the last 30 years and have had a CC go bad one time. Something broke loose inside of the casing and was causing a clog, which choked my car exhaust, which made me not go forward so well. It was my car in college, a Toyota Celica. Point is that it happens...
You have some good alternatives on here that you should definitely explore, an aftermarket cat would seem to be the way to go.
So I found the law from EPA.gov and called the dealer to explain. They claimed that the tech wrote down the mileage wrong. Instead of writing down 11k, they wrote 111k. I think that's BS and they are just blowing smoke up my butt for covering for their attempt to try to get 4k out of me. My car does NOT look like it has anything near 111k on it. They are going to call me back today with their "decision."
What a bunch of CRAP!! They knew what they were doing.... 11 vs 111... HA!!
