Catalytic woes
Catalytic woes
Good afternoon guys... I own a 2009 XK with approx 30k miles on it. It’s well maintained, upgraded the complete exhaust with Velocity 200 cell stainless steel cats and complete stainless Larini club sport exhaust. I’ve noticed a strange smell during hard acceleration and a sluggish return to idle response. I’m suspecting clogged cats but I’ve had them less then 10k miles. Any thoughts?
Mine failed completely at 7500miles less than a year since I got them
Hey Many! I think I mentioned to you the potential issues with high flow cats , as I have had. Can you easily take them off to see inside ? If you had an r car there is an easy way to tell if they are getting clogged by monitoring boost, on your might have to take a peek inside the actually cats
Well you need to log boost at wide open throttle in second gear for example. You simply compare it to stock or what your stock boost should be. Any restriction in exhaust will cause boost spikes. For example when my catsmelted boost went up by 2 psi
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
I look at logs all the time so can probably spot it better. I look for boost spikes outside of normal for that particular engine . I have logs from different customers cars to compare to. I would need mid to 100,% load at WoT to look at . Another tip on a sign of clogged catalytic converter is sound, usually the exhaust becomes quieter the more catalytic converters are clogged
__________________
badicedog (08-14-2020)
Can do an oxygen drop-down test to check the cats. See how long the downstream takes to react to input from STFT changes. Cats should follow 6-10 seconds behind, manifested in the downstream O2 sensor graph.
But back to WHERE'S my Upstream sensor? It's not listed as supported in Torque. The OTHER bank's sensor is there and operates.
