CATS SUSPENSION Pinpoint tests help
Old 11-22-2021, 11:21 AM
Neville Hobbs's Avatar
Originally Posted by Bill400
Neville,
Thanks for the excellent photos. The ground off spots are understood to obscure ID to allow after-market distribution by the OEM supplier.
What brand are they? Are you satisfied that they are OEM or equivalent?
Bill
They came in a Lemforder bag and I am satusfied that they have been made by Lemforder, OEM.
same is true of these.
  #62
Old 11-30-2021, 02:10 PM
Sean W's Avatar
Received 4,256 Likes on 2,379 Posts
Default Back on topic and update time
If anyone hasn't died of boredom yet, this will surely nudge you along because what's more exciting than suspension? Paint drying I suppose.
Wheel - Right rear wheel was in fact slightly - "ever so slightly" out of round. I should get it back today or tomorrow.
I replaced the brand new Mevotech rear upper A-Arms with some brand new generic ones off fleabay as I said I feel like something is binding. The generics feel more forgiving when I lift them by hand and before attaching to the hub. We shall see once I get the wheel back if there is any actual on the road improvement.
I also manually tested the ADCM and dampers. Dampers measuring between 5 and 6 ohms @ the damper and a little higher @ the ADCM. They are not leaking and there is no sag in the springs. Voltage to the accelerometers is correct @ 5 Volts. Return is 1.68 ish volts.
These are also the readings live while driving so I am moving on from the ADCM, unless someone tells me I missed something.
If you're still awake at this point, congrats.
The following 3 users liked this post by Sean W:
kj07xk (11-30-2021), peterv8 (12-01-2021), tmich (11-30-2021)
  #63
Old 11-30-2021, 05:00 PM
Sean W's Avatar
Default A vast Improvement
Went for a quick drive after mounting the tire. Same drive and everything was vastly improved. Not perfect but much much better. Now I'm convinced it's the upper A Arms. Sadly, I'm returning the as they don't have a notch for the ride height sensor so it sits loose on the arm. I will buy Lemforders. Hopefully Rock Auto will accept the return.
The following 2 users liked this post by Sean W:
hafren (12-01-2021), V7Sport (11-30-2021)
  #64
Old 12-01-2021, 01:26 AM
Have you checked the speed signal from the instrument cluster is reaching the CATS module using live data?
Did you check the bushings are rose type and not Polybushes?
Sean W (12-01-2021)
  #65
Old 12-01-2021, 08:54 AM
Sean W's Avatar
@Neville Hobbs thank you. please see post 38
https://www.jaguarforums.com/forum/x...2/#post2465377
This is the only data produced during a live run. I printed this on using the Autel wireless dongle but the SDD software displayed the same information on the laptop so I'm not sure how to confirm the speed from the instrument cluster is reaching the CATS module but as I stated, there are no codes thrown and if there were a disconnect, I should see code U015587 - Lost communication with instrument cluster, no?
If you could show me a snapshot of where I might view this in SDD I would appreciate it, although as stated above, I believe the issue is physical and not module related. There were absolutely no issues with ride firmness prior to swapping the control arms.
The bushings are not poly.
  #66
Old 12-02-2021, 04:01 AM
I do not have SSD but a pal has. He sat in the car whilst being logged into the suspension module and read out the live speeds which went something like this:
The figures were erratic indicating a problem which turned out to be the speed carrying wire earthing out along its route from cluster to CATS module.
No codes at all.
Perhaps you trapped a wire!?!?!?!??
Just something for you to investigate.
hope it helps.
Sean W (12-02-2021)
  #67
Old 06-06-2022, 05:09 AM
Whats the end result?
Sean W (06-06-2022)
  #68
Old 06-06-2022, 03:23 PM
Sean W's Avatar
It was as I said, the upper arms in the rear. Replaced them - all is well
Bill400 (06-07-2022), guy (06-07-2022), Neville Hobbs (06-06-2022)
Leslie Graham (Levitikon)
07-12-2021 08:05 PM
a04054
04-28-2018 04:00 PM
wfd59434
04-21-2012 07:09 PM
tbird6
01-10-2010 02:49 PM
racerx82
07-18-2007 09:50 PM
Quick Reply: CATS SUSPENSION Pinpoint tests help
