Center Console Cover Replacement
The latches on the center console lid on our XK are broken. I've used cabinet door magnets to keep it closed but now I have a working replacement.
Problem is...I can't find a way to remove the felt lining of the console. There are no visible screws and it seems like it's glued to the console itself.
Does anyone have a solution for this?
A photo would be helpful, and you need to add your location to your signature.
Used OEM lids occasionally show up on Ebay. Here's one that appears to match your interior, complete with brackets, for $116.41 delivered:
https://www.ebay.com/itm/16519124637...mis&media=COPY
Leather can easily be re-dyed to look almost as good as new.
See this thread:
https://www.jaguarforums.com/forum/x...-stuck-201013/
To do that, I need to remove the console interior to get at the screws on the hinge without having to cut the lining back near the hinge, or worse, to have to remove the entire console.
Received 2,048 Likes
The following 2 users liked this post by kj07xk:
Hockey_Steve (05-18-2022),
Stuart S (05-16-2022)
Sorry I didnt see this sooner. Anyway for those of you that stumble across this thread, you have to remove the leather trim on the sides of the center console ( they pop out with a moderate tug) to access the screws that hold the main hinge of the cubby lid/ center arm rest cover. If you have the workshop manual, it covers it in great detail.
