Center console disassembly?
Old 02-07-2011, 10:00 AM
AirCav's Avatar
Default Center console disassembly?
Could someone with access to a service manual please help me with disassembly of the center console? Maybe post a relevant page or two? I could probably figure it out with a hammer and pry bar but I'd really rather not break anything if I don't have to.
I need to remove the armrest storage, ashtray, and maybe shifter, to re-route some aftermarket wiring. Thanks in advance!
2008 XKR.
Old 02-07-2011, 11:04 AM
xksofia's Avatar
Default Manual
hi,
I think you can use this guide http://topix.jaguar.jlrext.com/topix...d=182&id=70685
for the installation of the music interface..
or if you have any problem opening the link mail me so I can send you the pdf
AirCav (02-08-2011)
Old 02-07-2011, 11:07 AM
xksofia's Avatar
Sorry....
my mail is tomovster@gmail.com
Old 02-08-2011, 11:38 PM
See if this helps!
Cheers,
File Type: pdf
AirCav (02-09-2011)
Old 02-09-2011, 12:27 PM
AirCav's Avatar
Originally Posted by xksofia
hi,
Thank you! I hadn't considered that those instructions might help. Lots of pictures!
Old 02-09-2011, 12:38 PM
AirCav's Avatar
Originally Posted by xjrguy
See if this helps!
Cheers,
Perfect! Just what I was looking for. Thank you.
When they say "Carefully release the 8 clips," or "Carefully release 11 clips" related to the trim panels, how do you release them? Are they just a friction tab fit that is simply pulled free or is there an actual way to release them?
Thanks again!
Old 02-09-2011, 01:34 PM
Thanks again!
Yes, they are just friction type clips; however, they are a tight fit. Plus the veneer panel is such a tight, flush fit that extreme care must be take to get under its edge without damaging it. Use something like a plastic putty knife for instance.
Good luck.
Old 02-09-2011, 03:05 PM
AirCav's Avatar
Good luck.
Old 02-17-2011, 11:51 AM
Here is some more info that may help in the dis-assembly.
Hope it helps.
Cheers,
File Type: pdf
AirCav (02-18-2011)
Swagguar
08-11-2019 04:50 PM
adam699
10-13-2015 05:53 PM
goingjag
09-30-2015 09:27 PM
42Ajd
09-26-2015 07:04 PM
Quick Reply: Center console disassembly?
