change air cleaner on xkr?
The front tires need to be removed, the inside fender skirt removed and then you will see the holders for the air filters in a case/box. The air filters slide out.
There are sensors in the case/box so be careful and remove the air filters carefully.
There are about 7 screws that need to be removed in order to bring down the inner fender skirt.
After you do the first side the second side gets easier.
I am sure that you bought the matched set of K&N's.
sherbercars (06-29-2014)
Beardy
09-18-2015 10:00 AM
