Change in message center about tire pressure system failure
Okay, guys and gals.
I have admittedly neglected to deal with the "Tyre Not Monitored" message (graphically indicating the right rear tire) that has been up since we bought our '07 back in November. Bad, bad bad bad Jaguar owner. I never found out if it was just a TPM that lost it's battery life or if it was a dysfunctional radio monitor. Again.. I hang my head in shame.
About two weeks ago, the message changed to "pressure monitoring system failure" or something like that. Does this indicate that more than one TPM has gone bad? Is this a different problem like a fuse? I am about to order 4 new TPMs, but would love to know what to expect from my mechanic when I take them and the car to him.
Thanks in advance.
George
Thanks in advance.
George
VDO SE53001 Tire Pressure Monitoring System (TPMS) Sensor | RockAuto
This is the best price I can find. Anybody beat this? I tried to find a "4-pack discount", but no luck.
Geosnooker2000 (09-19-2017)
Could have saved a couple dollars each, by going with the 53004:
VDO SE53004 Tire Pressure Monitoring System (TPMS) Sensor | RockAuto
It's a newer version of the 53001. Had them installed last year, no problems.
Cost me ~$49 each on Amazon then, nice to see they've come down in price on RockAuto.
Just to put this thread to bed, I took our XK into the tire shop yesterday with four new TPMS in the front seat. Of course they said it was going to cost more than just installing them because they had to hook them up to the computer and recalibrate blah blah blah... I told him, that's not consistent with my information. Then he said, well I'll put anything in your car you want, but it just may not work. I said thank you. Less than 5 miles down the road afterward, I was looking at a digital clock face! Thanks, everybody!
The following 2 users liked this post by Geosnooker2000:
kj07xk (09-27-2017),
Ranchero50 (09-27-2017)
Hey Chaz, check out this thread. I had the same issue. The short of it was to bump up the pressure on all tires to about 40psi and leave it for a while to see if the message clears, then drop down to normal over the course of a few days (weeks in my case).
https://www.jaguarforums.com/forum/x...o-away-183195/
chazaroo (09-28-2017)
Again, for anyone else out there with a persistent warning on the dash...
Push the little red triangle on the bottom edge of the touchscreen, a ways from the right bottom corner. That brings up the CLEAR WARNING box, then touch CLEAR WARNING. That clears it and brings back the clock. Multiple warnings, multiple clears...
I will look for that next time we run low on washer fluid, But I don't ever recall seeing that. And if it's red, seams like I would have noticed it.
Interesting...
ETA: It appears you have a 2010. Maybe your system has that and mine does not?
Interesting...
Naw, there is a guy that works there - he is a Jag guy. But the owner... I have been going to this shop for 20 years. They advertise mostly as a tire shop, but they do everything (except tranny rebuilds). I think he's just got this standard shpeal about every segment of your repair request. Like boilerplate language to cover his *** on costs.
Sorry, my bad.
