Changed tires and 2007XK won't start!
I just put on the summer mags and tires with the aid of small hydraulic jacks. Then I went to move the car, and nothing is happening. The start button doesn't react. I put the fob in its holder and it was received but still no ignition lights. Used the second key fob. The only lights are in the trunk when I used the metal key. Next I may use the key in the door lock.
I need other ideas!
Just the small rear parking lights are on with or without my 2amp maintainer.
I need other ideas!
steve_k_xk (03-15-2024)
With a battery that got low enough to not start the car, it probably will not last much longer. Just be aware and prepare yourself for a replacement.
Received 1,177 Likes
RichardS (03-14-2024)
I see it a bit differently. I am quite sure the battery is good, but a set of circumstances got it at a weak moment. The tendency in the forum is to plop in larger batteries, to supply the too many computers with their need for amps, even while sleeping.
I have been using the car as a daily driver for short distances in 15F degree days, and not using the battery maintainer. Because the alternator is setup for an OE smaller battery, mine won't get a full charge as a daily driver of short trips.
AGMs can be drained to a relatively low level, without performance consequences.
Now I will use my maintainer, to cover the shortfall of the alternator.
I thank Cee Jay, for his quick and accurate response!
Editorial comment, I guess. If anyone want to own a 10-14 year old Jag...get a jlr compatible reader and a DVM. Less than $100 combined on Amazon. Always welcome to help with any questions, of course, but if your car won't even respond to the start button, meter the battery for starters. Then hook up your Autel AP200 (or equivalent jlr compatible OBD) and get some actual data to work with. It's tough to offer useful feedback to "My car won't start".
The third thing to do when the car doesn't respond to the start button is the (factory recommended) hard reset. Remove both battery leads and hold them together for 30 seconds. Then reattach them and test the start. My '07XK NA will get it's brain occasionally scrambled when I pull out the OBD out without shutting down the app first. A 10mm wrench and a hard reset later, it starts up. Happened twice, both with me impatiently removing the OBD scanner before the app was shut down.
These aren't expensive tools -- they're equal to 1/2 hour of a mechanic's time. Help us help you (all) by providing us real data to work with. Oh, and the year, model and mileage helps a lot, too.
I do agree to having too many short trips can affect the charge. Hopefully that is your entire problem.
guy (03-16-2024)
Another one to watch on these aging cars is the alternator. Should hover around 14V in operation.
As mine began to die, the voltage generated began to decline into the mid 13's. Probably a failing Regulator or bad brushes, but then it abruptly failed completely.
Didn't tear down the old one to examine, as I needed to return it to cover the core charge.
... The third thing to do when the car doesn't respond to the start button is the (factory recommended) hard reset. Remove both battery leads and hold them together for 30 seconds. Then reattach them and test the start. My '07XK NA will get it's brain occasionally scrambled when I pull out the OBD out without shutting down the app first. A 10mm wrench and a hard reset later, it starts up. Happened twice, both with me impatiently removing the OBD scanner before the app was shut down. ...
It's easy to do, doesn't cost anything, and it's worth a try. Good luck, and let us know what happens.
Stuart
Well couple of overnights on the maintainer (2amps) and all is well. I have a clone of the CDs to address the SDD, found the cables in the center consol and hope to reach the main computers sometime in the future, if needed. While driving I have been using a ELM 327 and my phone, to check on water temp and charging rate, but my new HUD P8 digital gauge just arrived. I will let it sit on the left of the dash by the post and show me the coolant temp and Kms/hr speed, while driving all summer long.
amazon.ca/wiiyii-Display-System-Installed-Pillar/dp/B0957V8VMC/ref=sr_1_8?dib=eyJ2IjoiMSJ9.2GV_SykWbWqtM0
Next on the list is to break into my glove box without breaking it, and schedule a wheel alignment and inspection. It never stops. But the pleasure never stops, as well!
That’s the best thing about these cars: whatever the trouble, the pleasures never stop, and they almost always outweigh the troubles.
I can knly reiterate here that I owned a range of BMWs, small to large (325i to 730i), other Jags (XJs), previous XKs… none of them matched my XKRs (4.2 X150) on any serious account.
Downloading zeros disables your vehicle and is very time consuming (but educational) to resolve. There are better ways to use your time/learn SDD.
2. Your glove box is likely stuck in valet mode. Check that first.
Post your experiences to share with others.
Best of luck!
Bill
Stuart S (03-19-2024)
Josephh
XF (X260)
01-03-2024 02:55 AM
TimT
General Tech Help
08-10-2021 02:07 PM
