Chrome Grill
Mina Gallery $175 ask Chris for a Forum member discount. Fits on top of OEM grille, DIY. Search for reviews on this Forum.
https://www.minagallery.com/jaguar-x...nless-07-2009/
yea I didn't like the look of the Mina grill. I ended up buying an OEM chrome one from a forum member for my bottom grill (so they are both chrome now). You can buy them directly from Jaguar also.
https://www.jaguarlandroveroemparts....Y4LWdhcw%3D%3D
Removing and replacing a grill requires removing the bumper cover, which is a pain. Technically, it should be easy, but it requires removing many fasteners. Just did it on my '07. Factory shop manual describes the procedure in part and poorly.
First, the headlights do not need to be removed. Just loosened is enough. When all the fasteners have been removed the bumper cover will "sit in place" as though all fasteners remain attached. Final removal required moving the cover forward, not downward. The cover is held in place by two hidden male "locators" which are vertically mounted to the body. Factory suggests this is a "two-person task", and I think it is. The cover does not easily slide forward. It sorta just releases. Reassembly is the reverse and definitely requires two people to line up the locators.
It was not possible for me to remove the grill without removing the bumper cover on an '07. I tried. The bumper cover removal process requires removal of the frontmost "belly pan". There was not enough space to wiggle the mesh grill downward and out. Alternatively, I considered unfastening the grill from underneath (11 or so clips) and then wiggling the grilI outward from its opening. There was not enough room for my arm to reach upward to unfasten the clips that retain the grill. Whatever..... anyone R&Ring a grill must remove this front belly pan; and at this point will be able to see for themself whether or not the grill can be removed though the bumper cover opening.
gdhaliwal23
09-02-2017 12:50 PM
FS[MidAtlantic]: Jaguar XJ8 X350 2004-2007 grill veins / grill insert
magmedia
19
04-01-2014 10:18 AM
Jagman04
07-03-2010 02:38 AM
