Chrome "lining" around gear shift
Old 05-11-2018, 08:02 AM
Sean W's Avatar
Received 4,219 Likes on 2,367 Posts
Originally Posted by neo4star
after that remove the gear knob then you could remove the plastic cover.
Thanks Frank. How is the gear knob removed? I don't have this issue but would be good info for this thread.
  #42
Old 05-12-2018, 02:45 PM
Jdrasp's Avatar
You are right about the autoCOVR. I mentioned this to him and he said the part was too complex. Oh well thought I might have found an answer for you guys with the problem.
  #43
Old 05-12-2018, 07:29 PM
sov211's Avatar
Received 2,245 Likes on 1,361 Posts
The gear knob just unscrews - but there is a dab of locktite or similar on it, I think so you need to "break it free" to start.
Sean W (05-13-2018)
  #44
Old 05-12-2018, 08:04 PM
Stuart S's Avatar
Received 6,285 Likes on 3,449 Posts
I know that Forum member Richzak had a difficult time removing the shifter knob from his 2009 XKR Portfolio convertible. He preferred the design of one of the genuine Jaguar accessory knobs and, unfortunately, buggered the original Portfolio knob while trying to remove it.
Heating the shaft with a hair dryer or heat gun might soften the adhesive and make it easier to unscrew the knob.
Sean W (05-13-2018)
  #45
Old 05-13-2018, 01:51 PM
JustNiz's Avatar
Yep I can confirm it is an SOB to get off.
I was using heat and plenty of grunt but still had to give up trying before I broke something else.
  #46
Old 05-13-2018, 02:55 PM
Stuart S's Avatar
Anyone know "the secret" to removing the shift knob?
  #47
Old 05-14-2018, 10:01 AM
sov211's Avatar
well, I wrapped padding around the knob and then twisted it free using vise-grips. It is just screwed on - there is no fixing screw - but as I wrote earlier I think a drop of locktite or similar was originally employed to keep it tight.
The following 2 users liked this post by sov211:
Sean W (05-15-2018), Stuart S (05-14-2018)
  #48
Old 11-25-2019, 10:42 AM
rogers1511's Avatar
Default 2007 XKR Shiter Knob Removal
My 2007 Maintenance Manual says to release the lower cone shaped retainer/locking part then you can unscrew the handle. The retainer part is very hard to grip onto with out damaging the chrome surface, I believe there is a tool that should be used to grab the three equally spaced holes around it. I got it to move down a little so that the spacer ring is loose but not far enough as the handle just keeps spinning without coming off.
May have to make a tool for the lower retainer part if I cannot find it. Anyone know where to get the tool ...if it exists?
  #49
Old 10-25-2020, 06:09 AM
paulgorringe's Avatar
Default solved
Hi all
The chrome around my shifter started peeling and rapidly got worse until I had to do something.
The replacement parts are stupidly expensive as it is the whole shifter assembly.
My solution was to sand the plastic chrome and paint what was left with satin black to make it invisible under the aluminium overlay I purchased on E-Bay.
Fitting was easy once the gear knob and collar were removed, I got lucky and they came off together just by turning anti-clockwise, it was tight but only needed hands not tools.
This addition has transformed the appearance of the shifter area and totally hidden the peeling chrome.
On the photos the overlay looks slightly brushed in effect, however it is not as noticeable in real life, perhaps the effect of the flash?
The following 3 users liked this post by paulgorringe:
JonWat (06-14-2021), ralphwg (10-26-2020), Veesixjag (10-25-2020)
  #50
Old 10-25-2020, 10:03 PM
Veesixjag's Avatar
Originally Posted by paulgorringe
Hi all
I did look at this aluminum cover until I read you can still see the chrome around the gate area once fitted (my chrome has peeled and looks pretty crappy)
Like how yours turned out , gives me a little hope now. May try this mod
  #51
Old 10-25-2020, 11:25 PM
u102768's Avatar
Received 1,490 Likes on 908 Posts
Those aren't horribly expensive:
https://parts.jaguarhiltonhead.com/o...panel-c2p14202
  #52
Old 10-26-2020, 07:05 AM
Stuart S's Avatar
Originally Posted by u102768
That's not the part with the J-gate.
  #53
Old 10-26-2020, 05:51 PM
u102768's Avatar
I know but I posted it in case he was talking about the chrome surround as it wasn't totally clear.
  #54
Old 06-13-2021, 11:46 PM
Andrew XKNyc's Avatar
Default Perfect
Hello would love it you could guide me thru this process, where did you buy film? How did you get that cool font etc....THANKS
[QUOTE=paulgorringe;2307840]Hi all
  #55
Old 06-14-2021, 12:44 AM
Les H's Avatar
Hi
Terry's lists this part for $549 .
Les H
2009 XK Convertible
2017 F-Pace
1974 SIII E-Type OTS
1956 D-Type Replica
  #56
Old 06-14-2021, 09:49 AM
Andrew XKNyc
the overlay with the font cutouts was purchased on E-Bay and is a simple matter of sticking on.
Link to part https://www.ebay.co.uk/itm/303727855...IAAOSwFwVfha~T
The following 2 users liked this post by paulgorringe:
JackJohn (06-18-2021), Stuart S (06-15-2021)
  #57
Old 03-19-2022, 01:20 PM
JagXK2009's Avatar
Same problem as the original thread subject ... "Chrome lining around gearshift" is peeling. The part number is C2P5184 and it's over $500, which is insane. I was told because Jaguar still controls the pricing. Anyone yet found a solution as it's now March 19, 2022 ?
  #58
Old 03-19-2022, 02:12 PM
Cee Jay's Avatar
Received 5,360 Likes on 3,174 Posts
Yes, read this thread. There are a few option listed.
  #59
Old 03-20-2022, 07:15 AM
jahummer's Avatar
Received 2,367 Likes on 1,482 Posts
Considering for the price you’re getting an entire new shifter assembly, I think it’s quite reasonable and about the same cost as one from Toyota for the Camry, as an example. Also since it’s a genuine Jaguar part, who else do you think should “control” pricing?
If you want a used one they frequenting come up for offer on sites like eBay and the classified here….
  #60
Old 11-17-2022, 01:15 PM
malcolmgilbert's Avatar
Hi there,
Paul refered me to this forum and suggested I post the link to our website: www.solarsigna.com
Hope this solves your problem and thanks again Paul.
Best regards,
Malcolm
jaggedy
11-20-2022 12:09 PM
Jandreu
06-30-2022 03:10 PM
Will P
09-19-2018 08:36 AM
daverb
10-28-2015 10:18 AM
AtholC
09-09-2015 09:07 PM
Quick Reply: Chrome "lining" around gear shift
