cleaning throttle body
Received 1,103 Likes
Hey guys!
Actually, I’ve never cleaned the throttle body on my car. Which is peculiar as I did this annually on the xjr, and do this every other year on the S-Type 4.0.
My question is; How often has your throttle body been cleaned? And do you notice a difference? What is different?
I suppose I was just avoiding the replacement of the coupler, which is crazy.
Cheers!
Cheers!
If you do, have a new coupler ready.
I only cleaned mine when I had the S/C out. I installed a catch can at the same time but not sure if that kept the TB cleaner or not. It still looks pretty clean last time I looked, almost 30K miles after the catch can was installed.
You can always take a peek and see how dirty it is. But I wouldn't bother unless youre in there doing other stuff.
guy (06-11-2021)
I know on the 4L X100 XKR I have, the intake seems to get more "crap" in it via the emissions system, and I know some earlier cars had issues with throttle bodies actually having mechanical issues. I am unaware of that affecting the X150 in any variant.
If you are doing anything that requires pulling the snorkel bit of the intake off, you could check, but I don't recall mine ever looking bad and I have 74k miles. Popping that off if you want to check is super fast too; at least on my 07 XKR it is.
guy (06-11-2021)
I haven't done it on my XK N/A but did on my SV8.
I used this kit (overkill) -
I had a rough idle, not terrible but when I removed the intake manifold and lifted the butterfly valve, it was black inside the throttle body.
I started with cleaning the throttle body using the intake system cleaner and I dumped the fuel treatment into the gas tank. I had to feed the straw in carefully so the vehicle would idle properly while the can was draining.
Once done, I removed the intake again. The TB was clean. I didn't want to remove the moly compound on the butterfly valve, so I focused on movement of the butterfly valve itself by hand. I sprayed and cleaned the pivot points with a tooth brush. I also cleaned the TB where the butterfly valve makes contact with the TB.
Rough idle issue resolved. Also had a bit of a lurch on the accelerator beforehand and that went away too,
I'd say I left 98% of the moly untouched. My assumption was, I could always remove more.
From Popular Mechanics:
Some throttle body bores have a coating to reduce the buildup, but, in time, bores with protective coats can be affected. There are several ways to clean out the area. The best is with a professional tool called the Intake Snake, which comes with an effective yet safe solvent, and the simplest is with an old worn-out toothbrush with soft bristles and a mild solvent.
There are three reasons why you have to be careful, both in choice of solvent and in application: First, if the throttle body has a protective coating (as on many Ford products) to reduce the buildup, a strong solvent and hard brushing will remove it, so you'd have to do the job more often. If you see a warning label on a Ford product, that's why.
guy (06-11-2021)
I had planned to clean my throttle body when I change my SC coupler but I am pretty sure the service manual said specifically not to clean the trottle body. I was surprised as I've done this on my previous cars as routine maintenance. I will try to find the specific ref to post here. (2010 XKR)
From the 4.2 liter service manual:
CAUTION: Do not attempt to clean the throttle body. The bore and the throttle plate has a special coating applied during manufacture which should not be removed.
From the 5.0 liter manual:
Do not attempt to clean the throttle body bore, build up of deposits reduces air leakage past the throttle plate at the fully closed position.
On my 07 I did clean the body where it meets the butterfly valve with no ill effects on the teflon coating of the plate itself as I only focused on the pivot points. My car, my money....
guy (06-11-2021)
Sean W
01-03-2014 04:47 PM
