climate control question
You will always have to set the temperature; if you want the outside air to be neither heated nor cooled, set the temperature all the way down and then turn off the AC compressor by using the touchscreen:
1. On the Home screen, touch CLIMATE. That brings up the Climate menu.
2. On the CLIMATE screen, touch ECON, which turns the AC compressor off. The light on the AUTO rotary control knob will turn off to show that the compressor is off.
You can control the fan speed with the AUTO rotary control knob. To turn the AC back on, press the AUTO button on the rotary control knob and it will illuminate to show that the compressor is on.
I hope this answered your question.
Stuart
Stuart
blackenedindustries
09-30-2015 10:17 AM
dmatthewman
09-30-2015 10:10 AM
