Cold Air Intake??
Cold Air Intake??
I was looking around for a cold air intake for my 2008 jaguar xkr.
I can't seem to find one.. do they not exist for the car or am i missing something? (just got the car a week ago so im noob lol)
ah. just a minor inexpensive upgrade with better air flow into the car and a couple horses
The XKR uses dual MAF sensors which are very sensitive to flow inbalance. The factory intake isn't drawing hot engine bay air anyways so likely not much more power to be gained than from an air freshener hanging from the mirror Sometimes it's best to leave things alone...and this is probably one of them.
Bruce
Bruce
Why don't you measure intake air temperature? I think you will find that Jaguar has done a pretty good job at reducing difference between ambient and intake air temperature. This can easily be measured with a plug-in ScanGauge.
If you want to reduce air temperature at the intake ports, then the best way is to try to fit larger intercooler radiators. This may not be possible, and, at best, would be a custom job.
