Cold idle speed query
Morning all !
Hi, just wondered what the normal cold idle speed should be on a 2006 X150 XK 4.2.
Upon initial start up seems a little high, an indicated 1500 for a few seconds then settles down below 1000. Car is in the uk and garaged so no excessive cold temp etc.
May well be normal but just seemed a little high to me ?
Sounds about the same as mine. At start needle jumps to 2K, once started drops to 1500 for a couple of seconds, then drops to 1k for a few more, and settles at 750 until engine warms up.
While driving it Idles around 550 or 600 can remember which but that's in gear. Never put back to neutral to see if it increases.
Seems high to me too but may be the norm for 4.2L X150 series.
Usually on cold start the ecm's are in open loop which varies the injector pulse enriching the mixture. After a period of time as the cold start sensor gets warm the system goes into closed loop. The higher idle is in the open loop phase and when it goes to closed loop the idle reduces down to about 750 rpm. I usually have around 1200 rpm on start and wait until the idle drops before I drive away. I also put the top down at this time as the increased idle keeps the alternator charging.
Thang Nguyen
10-12-2015 01:25 AM
NTL1991
XJ40 ( XJ81 )
09-20-2015 06:22 PM
