Common fuel leakage locations
I get a strong smell of gas once in a while
after shutting off car or starting car, it seems
To be coming from near front wheels, wondering
where I should check and how to check for leakage.
I've already checked the steel fuel line connections
on top of engine, and fuel rail, no leakage noted.
-No codes or performance issues
-all injectors were replaced a year ago
-no evap codes, passes evap test
Prettykitty (03-19-2024)
Found the leak, its drizzling from the front of the gas tank passenger side (US), yikes!!!
Im assuming this is coming from the top of the fuel pump. I know there was a rover/jaguar recall for something similar, anyone have any knowledge on this?need to address this ASAP
I believe XKs do not have access to the tanks fuel pump
From within the vehicle.
trkyam (03-19-2024)
paul-hb
03-07-2012 08:41 AM
