Computer going crazy
HI everyone,
Well the cat is sort of refusing to go into storage.. as the onboard systems are going nuts lately.. this results in the radio being muted every 2 seconds or so for about .3 of a second..
this is when the car is cold and about 5 minutes after start. That "muting" goes on for another 5 minutes which either results in a full reboot of the entertainment system (and than its all fine again).. or it just disappears..
But the other day, the system rebooted, came back.. except for the monitor in between the dials on the dash.. which means.. I cannot read the time, burned fuel, miles, etc.. the dials themselves still operate and are lighted.. its just the mid-screen.. the center console screen comes back and works afterwards..
really? as this happens while the engine is running, while on highway or regular roads.. I would assume the engine would be capable of providing enough charge/voltage at 2kRPM..
The convenience mode thing is the most annoying; the car leaves many modules powered up when you first switch off, so that they don't have to reboot if you re-start. It only powers them down progressively, as time passes and the car hasn't been restarted - full shutdown takes 30 mins. If you lock the car, they're all shut down fairly promptly. So, if something isn't working, you have to shut down, lock, unlock & restart - just stopping & starting won't necessarily do the trick, particularly with the major systems like the instrument cluster, the touch screen and the entertainment system.
guy (01-25-2016)
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
rothwell
12-17-2009 08:09 AM
