Conv Quarter Window cable off rollers
The cable came off its rollers on the left quarter window over the weekend. I have been working on it all day and it this point I have everything off and the regulator is loose in the well. Unfortunately, the window is in the down position and I cannot get it up due to the binding of the cable. Any suggestions? I did a search and found Philbone had the same problem with his car. He said it was a bear to get the regulator out because the window was in the down position but he didn't say how he managed it. Thanks,
Received 1,975 Likes
This suggestion sucks, but if I were totally stuck, I'd consider cutting the cable to free everything, finish the removal, and then send the regulator off to that rebuild service that has been referenced in earlier threads, for about $175, or you might just be able to get a replacement cable, and be good to go.
mike.keith4
04-27-2020 04:27 AM
Jag Pilot
07-04-2013 10:09 AM
