"Conv top not latched" - issues
Actually, my 2000 XK8 was the first car I've owned that latched itself.
My 1993 MBZ 600SL also unlatched and latched itself - both the soft top and the hardtop - with the push of a button. It was the first car I owned that had a power adjustable inside rear view mirror with memory (linked to the key fobs for 2 drivers with memory for the side mirrors, inside mirror, driver's seat and headrest, steering wheel, and radio presets). Overkill.
I ended up in electronic jail today. While trying to test for continuity in my driver door harness to fix a non-working puddle light in driver door only (still doesn't work
...different post soon) I ended up with the window half down after disconnecting the harness from the door module. About the time that happens my son wants to go for a ride...so I am game and its nice out. Of course, the next thing that happens is he pushes the top-down button and the top is stuck about 1 1/2 inches from the latch. I didnt have to disconnect battery: just followed everything below starting with "close both doors..." and got it all back in order in less than 5 minutes! Thanks to White XKR..again. Jac
![Confused](https://www.jaguarforums.com/forum/images/smilies/confused.gif)
Try doing the following in this order:
-Reconnect the battery.
-Manually lower the top as far as you can (It can take up to 30 minutes for the system to depressurize if the pump was recently run). Be sure to return the pump to automatic mode when done.
-Close both doors and reset both windows with the engine running. Do the window reset 3 times for good measure.
-Make sure the trunk divider is properly deployed and the trunk is shut.
-Attempt to raise the top again. Hold the button for 60 seconds additional if the top stalls. It should eventually complete the cycle.
-Close both doors and reset the windows again with the engine running and the top up.
If that does not work, then have the system checked out.
badonenow9
05-08-2016 06:37 PM
RichmondXK
02-04-2012 02:51 PM
vonsmog
06-10-2007 09:00 PM
03-13-2007 12:07 PM
