Convertible bay cleaning
I would like to clean around the convertible top and in the top storage area. Can I open the top half way and let the button go, clean stuff, and then press the button again to continue to open it up all the way? My manual said not to release the button until the top was completely open or closed?
I recommend doing this cleaning in short intervals. In other words do not keep the top mid-cycle for more than 2 minutes at a time or so.
If you keep it mid-cycle for longer, as the hydraulic pressure bleeds down the top will move and then the electronics and the hydraulics may get out of sync requiring you to go through the manual reset procedure. The short interval approach will avoid this issue.
