Convertible top -- bad developments
Old 05-27-2020, 01:56 PM
kj07xk's Avatar
Received 2,048 Likes on 1,372 Posts
Originally Posted by Cee Jay
Now wait a minute here....... could all this be caused because the actual TOP is too tight to close far enough for the latch pawls to engage the top because it is too far away TO latch???
That goes back to my post #20, with an out of position top cable. Guess I need to find that thread.
  #42
Old 06-01-2020, 08:26 PM
pk4144's Avatar
Default Last Update (HOPEFULLY....)
So where I'm at:
Top seems to be working, EXCEPT: sometimes, if I shut the car off while the top is in the fully-down, retracted position, when I fire it up again I get the hated red "HOOD NOT LATCHED" triangle.
BUT... so far, at least, the top goes up and latches as normal, rear windows go up, all good. Red triangle goes away. I'm hoping I can keep this going until I return to LA. Though I'm thinking of getting a new battery just for the hell of it.
(ODD OTHER BATTERY SYMPTOM: sometimes I cannot access the climate control screen. I can still use the rotary knob to turn the fan speed up and down, and it seems the up and down manual temp switches work so all is good. Only bummer is the cooled seats are unavailable. This goes away in a day or two. Maybe part of the same problem?)
The following 2 users liked this post by pk4144:
Queen and Country (06-02-2020), Tracee (02-11-2021)
  #43
Old 09-26-2020, 05:57 PM
pk4144's Avatar
Default RESOLVED
Posted this elsewhere but thought I'd throw it on here as well to "resolve" the thread. Upshot: sometimes a battery swap followed by a reset works, but sometimes it is indeed something else.
At least I'm now an expert in raising and lowering the top manually!
  #44
Old 02-08-2021, 10:43 AM
JagDavid's Avatar
If you're still having trouble with the flap, it's because the cord that's attached to the flap and then to the frame has opened up. Thus there's no tension on the flap to pull it closed. If the flap is stuck, it's because there are two tracks ... one for the front of the flap and on for the rear of the flap. The front flap is likely on the rear track, which is shorter, thus causing the flap to not move to the closed position. I just spent a day removing the interior in the rear to get to the flap mechanism and was able to repair the cord. I can provide more details if needed.
The following 2 users liked this post by JagDavid:
dag82 (02-08-2021), Stuart S (02-08-2021)
  #45
Old 02-08-2021, 12:50 PM
dag82's Avatar
more details would be great just in case any of us run into this problem in the future
thanks again
  #46
Old 02-10-2021, 03:12 PM
pk4144's Avatar
FWIW, on my right-hand side flap the actual small cord that pulls it shut is severed, and has been for a while. Flap is constantly in a fully retracted (open) position. Doesn't seem to affect convertible top opening/closing at all. I should fix it but it seems to have no ill effects.
jimi727
07-07-2020 07:55 PM
envincibal
05-17-2020 12:14 AM
JykiT
09-06-2017 10:37 AM
qcktvr
05-04-2017 04:30 PM
Nayzam
06-12-2016 03:44 PM
Quick Reply: Convertible top -- bad developments
