Convertible Top "Hood not Latched" - 2010 XKR Convertible (Drop Head Coupe)
I wanted to share this as sanity check for those of you that may have chased this issue. As with the other posts detailing it, my top also would come within a couple of inches of closing and stop. Across three days, I reset the top a bizillion times, reset the windows a kazillion times, released the tension a gazillion times, charged the battery, zapped the battery, burnt sage, and did a tribal dance naked around the car. Nothing worked. At my wit's end, I shamefully dialed the local dealer and scheduled an appointment. Jiggling the wiring harness he could see the sensor going on and offline. Sure enough, it was a couple of broken wires in the harness which he repaired.
For three days I thought that I must either be not performing the steps in the correct order or doing the incorrect steps to reset or restore the hood operation or something like that. This is why I'm posting this. Should you encounter the same issue and performed all of the resets and still have a malfunctioning roof, please check your wiring. You just may not be going crazy.
Two questions:
1. Which wire harness was bad and what was it's location?
2. Can someone tell me the location of the relays that control the rear windows on the XK conv.(are they marked and if not, then possibly the exact board locations if known) ? They(rear windows) were both up when I attempted to lower the top with the "convertible top latches not closed" warning and could never get them to close again. This is a salvage vehicle so I want to keep the inside dry if possible while awaiting rebuild. .
Wow, these tops are a complicated hot mess compared with to the coupes!
Received 2,011 Likes
They charged me for 3 hours of labor for this repair which seemed reasonable given that he spent at least two of those hours trying to find the issue.
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1219x791/pinched_wiring_location_5b2fea18b230f6c0005dd9308a7ca9c6d77af4bb.jpg)
