Convertible top plastic slide part
Old 01-07-2017, 10:08 AM
bjmawg's Avatar
Thank you for your knowledge and information,
when the weather improves, hoping to resolve this side panel issue,
just dug out the manual, whilst having a read, their maybe a possibility to remove the
"rear quarter trim panel" to gain access ?
Question: - do you know if the rear seats need to be removed to gain access to the screws to remove the "rear quarter trim panel" -
Thank you . . .
Old 01-07-2017, 10:29 AM
bjmawg's Avatar
just dug out the manual, whilst having a read, their maybe a possibility to remove the "rear quarter trim panel" to gain access ?
Thank you . . .
Old 11-21-2018, 11:04 PM
Geosnooker2000's Avatar
Bump so I can find this.
Old 11-22-2018, 10:43 PM
WhiteXKR's Avatar
Received 2,988 Likes on 2,125 Posts
Old 10-03-2019, 01:53 PM
Jeff Jones's Avatar
Guess I will have to pay the $185 estimate to see it it can be reattached. Would be happy to manually slide closed and open if possible.
Old 10-03-2019, 02:39 PM
Canadacat's Avatar
My string broke on one side but i was able to tie it back together in a loop and re attach it by stopping the roof half way up to get my hands in. I manually also put the slider back in the right track and so far all is good ( 3 months). Doesn't quite close tight but good enough for now.
badicedog (10-03-2019)
Old 10-03-2019, 03:12 PM
badicedog's Avatar
I’m in the same boat guys. I remember there was a thread on this. Looked like a Royal pain in the ****. Have to remove rear seats, side plastic inside cover and partially disassemble to convertible mechanism.
  #28
Old 06-29-2020, 11:45 AM
JP3507's Avatar
Originally Posted by Mkucharczuk
After a closer look that is exactly what happened to mine. How did you go about getting in there to glue on a piece of plastic to fix the problem? Thanks!
I saw your post from years back regarding the broken plastic track for XKR top. I have the same problem and was hoping you could tell me how you fixed your issue? I see another post from DAVE C of which you were conversing with him at the time but it looks like he was able to fix without removing anything. Where mine is cracked it is pretty far back and cannot get to it without removing things. Hope you can help me. Thanks
JP
NikiJ (02-05-2024)
Old 06-29-2020, 11:46 AM
JP3507's Avatar
Were you able to fix this cracked track? If so can you give me some advice on how to do so? I have a 2008 XKR
beasleee (10-03-2022)
  #30
Old 06-29-2020, 06:41 PM
badicedog's Avatar
Not yet, looking at options.
  #31
Old 06-15-2021, 07:29 PM
Steven07XK's Avatar
The sliding flap on my car broke again. The first time, the track section broke - so I removed the rear panel and glued the broken portion of the track in place and then put more glue (JB Weld Original) liberally and strategically around the track to reinforce it. That worked well. But last week the flap jumped its track again (probably after 100 times of cycling top) and in the process of trying to pull it out, the string came out. I fixed that my taking it all apart again, and taking the damper apart (the spring is really under load - my end cap landed about 40 feet away). I pulled the plastic piece out of the end of the tube. A part of the piece that held the string was history. So I drilled two small holes from the back of the plastic and inserted a thin piece of metal from a small key ring that I shaped into a U to go through the end. Once through I turned the ends with needle nose pliers so I would have something for the string to hook onto. I did it in such a way that the inserted metal did not affect how the spring seated itself on the plastic or hit the sides at all. Worked fine.
But the flap just jumped the track again. I stopped it before any damage was done. But this is getting old.
I am wondering if anyone has done something else to fix this - I can buy a new flap but they are not cheap. Although I would do it if the new ones have been redesigned? Has anyone tried to put something (like a thin plastic tube) over the pins to extend their length to keep them from coming out of the track? I am thinking of heat shrink 1/8 silicon tubing on the small pins? Or greasing the track? It happens when the roof closes...Could the string be under to much tension?
Any ideas would be greatly appreciated.
  #32
Old 06-20-2021, 12:42 PM
badicedog's Avatar
looks like I,m in the same boat. Will be a fun weekend
  #33
Old 06-26-2021, 09:35 AM
jwooky's Avatar
I have “fixed” them so many times I have gotten to the point that I just leave them disconnected and close them by hand.
Seems like they wear out to the point they keep jumping the track and get bound up.
  #34
Old 06-26-2021, 10:53 AM
Steven07XK's Avatar
@Jwooky I am now doing the same thing. I stop the roof half way, get out, disconnect the cable and push the sliding panel in. Then close the roof the rest of the way. But doing this has led me to believe I have figured out my latest issue, sometimes when I disconnect the cable, the panel does not immediately slide back in...I have to give it a nudge. If I don't do this, and the panel is sitting there when the roof closes - bad things happen.
Now I wonder if this latest return spring issue caused my broken track (that I fixed with epoxy) or the warping and bending of my panel/pins (that I fixed with a heat gun). Or did my return spring get damaged when those other things failed?
Can you tell me if your panel immediately slides in on its own when you disconnect the front cable? And if so, does it do it 100% of the time? If it sticks one time...its bad.
Can anyone tell me if Jaguar ever changed the return spring? Or if the sliding panel kits I see online have a different spring? I have an 07, is this an issue on newer cars?
  #35
Old 03-19-2022, 12:19 PM
beasleee's Avatar
Help Mates I'm in the same boat.
  #36
Old 05-09-2023, 01:42 PM
K Man's Avatar
Default plastic sliding piece for convertible
Originally Posted by DaveC
Just purchased an 08 XK Convertible and there is a small plastic part that slides to meet up with the tonneau cover when the top is down. It is working on one side but not the other. I can see the cable (cord) is not connected. Is this a major issue to fix and would it be covered as a Jaguar CPO issue?
BTW, pictures to follow. Pick it up next weekend.
Rear quarter casing
dealer says 410.00 Edison NJ
Thanks,
Rear quarter casing its Plastic dealer talking 410.00 !! American money too
NikiJ (02-05-2024)
  #37
Old 05-14-2023, 07:39 PM
ralphwg's Avatar
Received 1,211 Likes on 917 Posts
This is not an uncommon occurrence. There are several write ups as to how to make the repair. Check the stickies at the top of the lead page for this Forum and you may find directions to a write up. If that fails then use the search box at the upper right corner of this page trying different entries/words that fit until you come up with one of the threads. I have never had to repair the mechanism but it could be a diy if you think you are competent to do it.
JarodL
03-07-2024 01:39 AM
kelliott
05-31-2022 05:26 PM
davidladewig
09-03-2015 06:32 PM
pnwrs2000
09-03-2015 11:55 AM
TC Johnson
09-02-2015 09:30 AM
Quick Reply: Convertible top plastic slide part
