Convertor Warehouse has anyone done business with these guys?
They are out of TX and the prices on there O.E.M. style direct fit cats are outstanding. My 07 XKR right side cat is in need of attention so I am working on a 200 cell upgrade with a forum vendor but with some forum members experiencing issue's with codes on their XJ's I started to see what other options may be out there. I ran across these guys info@convertorwarehouse.com and can't believe the pricing. Has anybody used any of their products? I would really like to stick with my plans to go with a 200 cell upgrade but a bolt on stock unit for $300.00 is hard to not consider. What say you.
200 cell cats are proven to increase hp but at a cost which is the increased sound and fuel consumption in my case
If you don't mind the extra sound go for it as far as the codes coming up I've only had them appear twice both times on the freeway in the space of a year and I cleared then with my obd11 scanner ( mind you I have 100 cel)
However if your paranoid any good dyno tuning shop will be able to permanently switch them off
The drone is not present I've got the outer exhaust pipes (the ones with the valves inside) manually set in the half open position
The sound is a lot closer to a Aston now , even if that's too loud you can manually shut them completely I've tried this and yes it sounded great but the way it is set up now soundwise is perfect
Rocky15
05-13-2016 10:25 AM
