Coolant leak 2013 XKR
Hi,
i have a 2013 xkr and noticed a coolant leak which i think i have located. The leak seams to be in the back of the engine. Can someone please advise which parts should be replaced. Do the parts have to be oem or after market are acceptable. Also once this work is being performed should any addition parts be replaced or considered to be replaced. Thank you for any and all advice.
Mine leaked at the rear of the engine behind the intake stuff and onto the torque converter cover and such. I thought I'd found the dreaded Valley Hose problem so I had all the hoses on the car replaced. Turned out to be the Oil Cooler was doing the dripping and all the hoses were fine. Replaced anyway just cuz. Also replaced the oil cooler.
