coolant leak
As you have already posted an Intro on March 9th ( https://www.jaguarforums.com/forum/n...g-game-243872/ ), I've merged your two latest Intro posts and moved your question from New Member Area - Intro a MUST to X150 forum. This is the place to post technical questions about your model.
The following 2 users liked this post by GGG:
GetITcoy60 (06-23-2021),
MarkyUK (06-13-2021)
It would be necessary to remove the intake manifold if the valley hose has burst (which seems likely). I recommend to the OP that he take this opportunity to replace all coolant hoses.
The following 2 users liked this post by Patrick Wong:
GetITcoy60 (06-14-2021),
ralphwg (06-15-2021)
Received 2,682 Likes
If you plan to just fix the one leak, I'd clean all the coolant off, get a pressure tester and pressurize the system to pinpoint the leak while cold. It still may be obscured by your intake manifold, but cant help to make sure the coolant that has leaked has not moved around.
On my own car, since its 14, just like yours, I'd use this time to just shotgun the cooling system consumables. The little hard lines, the hoses, all done so that you aren't playing whack a mole over time replacing them onesie twosie. It'll be under a grand, even with Jaguar prices, and I think for a grand, you are buying a good bit of insurance since overheating would be the most likely reason your 4.2L car would grenade an engine.
The following 2 users liked this post by 80sRule:
Redline (06-19-2021)
Received 1,192 Likes
Four years ago I replaced all coolant hoses and the thermostat housing in my 2007 XK. Maybe you might find my post to be of interest: 2007 XK Cooling System Service - Jaguar Forums - Jaguar Enthusiasts Forum
Good luck with your repairs!
peterv8 (06-16-2021)
blaydes99
07-07-2014 10:41 AM
