Coolant Leak/Pressure Question
I should have added that I don't see even a hint of staining anywhere on the radiator fins or hoses in or out of radiators. They look practically brand new. I guess there could be a crack on the side that faces away from the sides that I can see easily, though.
XJ8Germany (04-25-2024)
bgpenguin21 (04-25-2024)
Received 2,048 Likes
See post No.4 and the endoscope duel camera with LED light, requirement for some investigative inspection for those difficult to access places.
Looks a little more forward & RHS than pouring down the back of the engine from the engine valley.
Could be the rear heater manifold spraying out on the right hand side, since leak pressure and temperature rated. But could be many things!! As you are seeing.
Without removing/lifting things like expansion tank and the windscreen finisher, and inspecting hard to say without playing guessing games.
Easier poking around with the camera in and around the expansion tank area, and move over to the usual suspects.
Thanks, guys. Sounds like getting some cameras setup, taking it out for a vigorous drive and looking for the leak hot and real-time is my next best option.
I will update next week, since the wifey and I are taking a long weekend trip starting tomorrow. The Gray Ghost will sadly not be participating this time. I told her since she is misbehaving she stays in the garage this weekend. The car, not the wifey. 🤔😀
On the Car, not the Wifey that is.
bocatrip (04-25-2024)
Here is what I would do. Wrap some cloth material around areas where you suspect a leak. Block radiator side from engine by cloth material or a piece of carboard. Drive around, shut down the engine and expect. You should be able to see from stains the area where the leak is coming from. Then, repeat the test focusing on the specific area. Just make sure material does not get loose and does not touch belts or exhaust.
#30
Also, big cause of overheat is thermostat. What temp are the water lines on either side of it at operating temp. You should know if the thermostat is opening just using an infrared thermometer. I get you're trying to find the leak but if you have opportunity to find out why it's leaking, all the better. I haven't been under my hood much in the past couple years. From those pics, is it possible leak is really overflow tank spilling out? Not a fan of wrapping the engine I any cloth. Consider Fluorescent dye.
The following 2 users liked this post by Sean W:
bgpenguin21 (04-25-2024),
bydand (04-25-2024)
#31
First, a disclaimer: I'm an amateur at home mechanic. (Read: fluids, filter, brake work and oil changes) But I'm a new empty-nester who's ready to sponge up some additional repair skills. This forum has taught me a ton already. Thank you to everyone that contributes to the cause.
The issue that I'm dealing with is a phantom coolant leak. I did some searches and read multiple threads, but I didn't run across any that seemed to be my exact issue in the same location. Possibly, the answer is already out there and it's just that I need a push in the right direction. Just believe me when I say laziness is not driving my post on the subject.
So, now that the preamble is out of the way. I submit for your reading pleasure (or pain)...
My Initial Observations:
coolant leak near reservoir tank
coolant leak near engine on passenger side (US spec)
coolant leak near engine and firewall
What I've Tried So Far:
What should I try next fellas?
Thoughts?
Slaps?
Advice?
Eyerolls?
Something else?
- Car has not yet overheated; at least not thrown a warning in the dash
- When the car sits cold, there are no obvious leaks and coolant level is stationary
- When I drive the car like I want to save gas mileage (not usually - haha) keeping it under 4k RPMs, no obvious leaks and coolant level let's say is mostly stationary
- If I drive her harder, between 4k-7k RPMs, there will be leaking on my garage floor and the coolant level will obviously drop
- To give you an idea of the amount of leakage... On an hour-long drive like this, the coolant level will go from the Max to the Min
- The leak seems to be somewhere closer to the reservoir-side of the engine; midline to top of engine on the passenger side (US spec) closer to the firewall
- Put on code reader and no faults
- Caveat: My code reader cost me $80, not $350+
- Drove around doing some spirited driving, came back to the garage, let it idle in park, gave it some gas
- No obvious leaks found real-time
- Rented a coolant pressure tester (MotoRad brand with correct adapter), put it under 29psi pressure
- No hissing, no gurgling, no bubbling, no obvious leaking
Thoughts?
Slaps?
Advice?
Eyerolls?
Something else?
Good point, but better monitoring the engine CW temp via the OBD port, with live data monitoring real time. see post one, 4k to 6k revs under load. So sticky thermostat is an option.
The following 2 users liked this post by bydand:
Sean W (04-25-2024)
#32
#33
I thought is was CW low level expansion tank only?
Could be wrong, but there are a awful lot of overheated v6 and V8 engines due to complete water loss on plastic pipe failures.
Would tie in nicely, with expansion tank being sick at high load, temp and a duff sticky thermostat.
Yes it does, in the screen display, Engine Overheating, page 186.
Last edited by bydand; 04-26-2024 at 01:15 AM. Reason: added page from owners manual on overheating.
bgpenguin21 (04-29-2024)
#34
I have just checked your car details 60k and a 2010 XKR. Is it the original thermostat?
Having just checked my 2013 with a 10-2012thermostat, 3.0Ltr , 66k miles on this thermostat and comparing the operation to the new plastic OEM thermostat, and the Alloy bodied thermostat for operating at temperature 100deg c, (boiling pan of water)
Checked the thermostat plunger movement cold to hot to cold. and measured the overall lengths.
The old original thermostat, was rather jerky in operation, not as smooth as the others. So well worth changing out. The rating stamped on the top was 95deg C.
The top alloy pipe was reading 100deg c at prolonged idle, and the fan was not running fast. as checked with IR gun. No obvious spillage on top of the expansion tank, but the felt sound deadening, below, and the bonnet sound deadening material was stained with salts. and both were clean after the maintenance last sumer.
Alloy, new OEM, and old original thermostats
the internals. all springs were same length, the spring carrier was slightly eroded at the top, and the top spring cap was cracked.
Yes I would definitely monitor the cw temperature in operation and see if it controls smoothly.
95deg stamped.
95deg stamped.
#35
95deg stamped.
95deg stamped.
darren-talbot
01-19-2013 05:10 PM
