Coolant level sensor
So my 2009 xk developed a leak in the coolant reservoir, specifically on the bleed screw. I ordered a new one and when I was swapping them out I noticed that my old one did not have a coolant level sensor installed. The new reservoir came with one but I don’t even see my connector/wiring harness for the sensor. I looked all through the wiring diagrams and it does not show one, but the repair manual does state that the coolant tank has a level sensor on it. The other strange thing is I don’t have a ETC for a missing sensor. And the other day when I first noticed my temp creeping up on me, my coolant level was low and I didn’t even stop to think about why my level sensor did not warn me. Any ideas? These cars do have coolant level sensors right?
Makes me wonder if I tucked the harness away when I did the engine swap because I didn’t find a place to plug it in. Still I would imagine that I would get a trouble code for a missing sensor.
Bob OB (11-27-2021)
Received 1,975 Likes
The following 2 users liked this post by jahummer:
AZCLAUDE (11-11-2021),
Vincesandoval718 (11-14-2021)
these coolant jugs must all be made by the same company; I had a 2015 VW CC with a leak & called the dealer to get one(100 miles away), but he said it is under warranty so bring it when you can, which I did.....Turned out OK, as they had to remove the front bumper to install the new one....
Armand
Armand
Thanks for the replies! I just wanted to make sure I wasn’t missing something. I just recently read up on that thread were a member set up an mcu and screen in the ashtray to monitor coolant temperature and other parameters. I’m betting some code can be added and that sensor can be wired up to monitor coolant level on 07-09 years.
if that is in fact how that specific sensor works, the code for the mcu would be pretty simple. Pseudo code= if (no continuity)
warning = “low coolant level”
else; no warning message
The mcu has multiple GPIOs and one can be used for that sensor. Then the info is displayed on the screen. No need to go through OBD.
