Coolant Preferences? Prestone Dexcool vs Zerex G05
It's actually very simple. Use any OAT / longlife coolant which is the same colour as the coolant already in the car, Probably pink/orange as that is the most common. If you wish to change to a different colour then you will need multiple flushes using plain, ideally distilled / deionised, water or you will end up with a murky brown colour.
Richard
Richard
jahummer (06-22-2024)
Coolant has become a freaking minefield
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
P.S. also write the coolant type you use down, or buy additional bottles of it, so that you don't have to do three weeks of research again when your overflow tank needs a little topup in a few years lol
Don B (06-22-2024)
Use the "Ford" stuff - WSS-M97B44-D, not sure what the D stands for concentrated according to tinternet - WSS-M97B44 is what the owners manwell calls for:
https://www.motorcraft.com/us/en_us/home/our-products/chemicals-and-lubricants/ac-and-engine-cooling-products/engine-cooling-system-products/orange-concentrated-antifreeze-coolants.html
Or you could use the pre-diluted:
https://www.motorcraft.com/us/en_us/...-coolants.html
Richard
Keep it simple, use DEX-COOL. Doesn't require lessons in chemistry or an engineering degree to figure this out...
guy (06-22-2024)
Thanks everyone... like i said it is a rabbit hole. Ford replaced their original orange coolant with yellow coolant that is supposed to be backwards compatible and mixable with the orange. Prestone does not officially list WSS-M97B44-D spec or the newer replacement spec that Ford Yellow has. Some places say that Xerex *is* the Ford supplier. My original inclination was the Prestone... i emailed them about meeting the old Jag/Ford spec but have not heard back. if I do, i'll post here.
https://prestone.com/product/preston...-ready-to-use/
https://www.walmart.com/ip/Super-Tec...1?from=/search
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
The following 2 users liked this post by jahummer:
BlkC4t_XK14 (06-23-2024),
RichardS (06-22-2024)
https://www.motorcraft.com/us/en_us/...stem-products/gold-concentrated-antifreeze-coolants.html
I already gave you the link to the orange anti-freeze.
That is so true. I have an X100 and and X150 and I've never spent more than a second in deciding which coolant, engine oil or gearbox oil to use.
The only fluid which required a little research was the differential oil which Jaguar are reluctant to publish any definitive specs for and which is why so many internet forums and YouTube creators use an oil which is thinner than Jaguar used on the production line. However, even that is not a big deal.
Richard
Richard
Richard
I didn't suggest that the colour told you anything at all other than what colour it is. All the widely obtainable OAT/ Longlife antifreezes can be mixed. You might be able to buy some weird stuff designed by NASA for the Space Shuttle but we're talking about the stuff you can buy at your local autostore. 😉
Richard
Richard
I was simply providing additional information for OP that "OAT" is not the same as other formulas that contain the letters "OAT," as it is very easy to hear a vague statement like "any OAT will work and can be mixed" and then come home with Si-OAT or something that is not the correct spec for the vehicle and/or will turn to sludge if you top up with something different later.
Richard
Every OAT type I listed is available at my local auto parts store in varying colours, and most of them cannot be mixed with the others.
That was the result of my research too.
If I remember correctly, VW spec coolant has changed from OAT to HOAT to Si-OAT over the past 10yrs or so (maybe not in that order).. I was advised they were "interchangeable" in my application, as in I can use any of the 3 in my Caddy since they were all specced for it at one point or another, but I was also advised to flush the entire system thoroughly if changing from one to the other. I wouldn't take this to be interchangeable in the sense "You can use any of the 3 in any engine that's specced with one of these."
I had no idea what type of coolant was in there when I bought it so, when the new heater pipes went in, we ran three full flush cycles through before filling it back up.
jahummer (06-23-2024)
