Coolant reservoir bleed screw / plug part sourcing
Anyone know where I can source the correct part for the coolant reservoir bleeder screw?
I believe it is 13mmx1.5 bleed screw. I've already replaced the reservoir so I just need the screw
the screw is made of hollow plastic fill and if you overtighten, it will shear off.
all of the ones I found online are 10mm and do not fit XKs/F-types etc.
UPDATE: There are 2 sizes being sold under the same part number, you will have to ask the seller
to put a micrometer on the plug. Currently britparts is selling it on amazon/ebay
There could be a 50% chance a plastic bolt has the same thread size. Add an 0 ring for seal and drill a hole vertical and horizontal for air flow. Finding the replacement bleed screw, will only come with a complete tank. Just another Roadkill repair!
