Cooling Fans ...again?
I searched and read everything I could find, but I did not find any solutions. Does anyone have any idea what would cause the fans to start as soon at the car door is opened? It clearly isn't an overheating issue and I doubt a stuck thermostat would be the cause either. Possibly a relay or sensor? Any help would be greatly appreciated!
I have the same problem as yourself . fan kicks on Full as soon as door is opens etc without starting the engine or ignition on , common problem i have seen as i googled it up some of the older jag models suffer from same , fix was either a new thermostat , new fuse , new relay or a new modual in some cases a broken or worn wire , Mine in garage at present for diagnosis
The following 2 users liked this post by George05:
DGL (01-09-2020),
SpinningWheels (01-08-2020)
Not for now on arrival to pick mine up around 12ish today owner was unavailable out on a test drive, so i just asked the receptionist who told me front some were they had to remove the front bumper fix the wire then put back on the bumper . car drove great well felt great after driving the company small van for last month then a big problem . hit a very l;arge pot hole at 70mph was lucky to gain control and swerved of dual carrage way without being killed ( i am quite shaken just now no hard shoulder to pull into and had to swerve over 3 lanes as you may well understand . i shall ask tomorrow what side the wire problem was on but sure it was the left passengers side UK wont be on till later got a shock
Received 1,103 Likes
Glad it ended well for you. Well done.
George05 (01-09-2020)
Richard Moss
06-22-2014 09:23 AM
