Correct Tyre Pressures 20" tyres on xkr
powerhouse (08-11-2014)
powerhouse (08-12-2014)
I.e. a "v"-shaped profile, instead of "|_|".
Apologies for the graphics!
Received 1,103 Likes
However, the door label on the 75 says 36F/33R, possibly because I have the 10.5" rear rims with 295/30 tyres. Might be the same for the R-S, too.
Door sticker tire pressures are the manufacturer's recomendations for the original equipment tires. Those pressures are merely the starting point for the owner, and can vary depending on the circumstances including, but not limited to, climate and road conditions. A pressure that works well for one brand/size/type might be off for a different brand, etc. Start with the manufacturer's recommendation and then try +/- 2 or 3 lbs or more. Pressures should be raised for sustained high-speed driving.
Examine your tread wear pattern monthly for signs of under/over inflation. Under inflation causes excessive wear on the outside edges; over inflation causes excessive wear in the center. Abnormal wear is more quickly apparent with 20" staggered wheels with directional tires since they can't be rotated and the fronts will wear faster. You should expect to get 1/2 the manufacturer's rated mileage (or less) out of a set of staggered directional tires since they can't be rotated.
Don't rely on your TPMS to keep the correct pressure in each of your tires. Get a good digital tire pressure gauge and check them monthly, including the spare if you have one.
My manual suggests to look at the door jam for proper pressures but on another page in the manual it lists 30/front 33/rear for 19s. Door jam reads 33/front 36/rear. I prefer if anything to be 3 lbs over inflated than under inflated and am going with the door jam or 33/f 36/r
