Cost of oil change at Jaguar dealership?
Jaguar dealer labor in Poland is expensive, just like in the USA.
Was wondering others thoughts. I purchased a 20k miles filter specific for synthetic oil. I’m changing my oil every 3000 miles. May be overkill but that’s what I’m doing. If I’m changing the oil and otherwise it would have been worse would others change the filter or let it ride for say…. 9000 miles? I’ve heard your supposed to change filter with oil regardless but it’s rated for 20k miles…. Hmmm
Oil is cheaper than engines. I change the oil and filter every 5,000 miles or 1 year, whichever comes first.
I'll never pay that crazy price for no oil change and then gotta turn around and buy the oil too.I change mine myself with a pump with a nozzle that attaches to the small iron tube that's located under the oil cap and i attach it to that and suck out all the oil and put the new oil in once i pump that thing until it can't pump no more where it gives you signs that it sucked out all of the old motor oil.once it's done i just put the correct amount of oil back in and it's good.It's fairly easy and you should learn how to do it yourself.Either that or take it to walmart and get it done for $30 where u just bring your own oil cause my lil bro told me the XK is the easiest car to work on, it's just the parts are too packed together under the hood that gives you a problem.The bolt you take off under the car is located under the plastic shield,so you just need to remove it to get to it to unscrew the bolt to release the oil.Maybe walmart use the same pump like i got to do it for you if they don't do it the old fashion way by removing the plastic shield under the car
Then I was thinking…. if filters are doing their job and in doing so, the medium becoming blocked, would that not affect flow??
So for the few dollars, I just have the filters replaced every time.
Ditto for all the air filters. I change them at half the schedule “suggested”. (I refuse to use the phrase “recommended” as I had one dealer suggest my frequent maintenance schedule was “not recommended”…. jeepers.)
As for suggesting one filter over another, there are significant differences in quality and features. I keep up on the independent tests by a few youtubers. If you strictly consider the marketing, you may be surprised by the descrepancies.
Cheers to all,
Lothar52 (06-04-2024)
#30
Genuine filter's only $22 and fits perfectly. Most members here probably only need a change once per year so not sure what the point of spending hours of research to saave $2-$5 per year. Also I've tried other filters and found they didn't fit as well or leaked.
#31
Your Public Profile shows that you have a 5.0L X150. Let's assume that your technician was a slow worker and he took 30 minutes to change your oil. (See my Post #9, above). That's labor only, because you brought your own oil (and, I presume, filter). So, $380 for a 1/2 hour's work equals $760 per hour.
By the way, a hand wash in my area averages around $50 and they aren't nearly as good as the main dealer.
#32
First, you can get just a basic oil change done at most main dealers for less than $200, just request they skip everything else such as the full service wash, loaner vehicle, inspection report, etc, in fact one of the dealers here occasionally offer a 30 minute oil change special while you wait for $120. Second it's quite easy to forget the costs of doing business, especially if you don't own a business. To simplify there's taxes, insurance, loaner vehicles, real estate, materials cost, fees, salaries and more so the actual NET profit's a LOT less than you think - oil changes don't keep main dealers in business. If you can't afford the maintenance and don't want to DIY then you shouldn't own one.
#33
I think we all get it - the cost of an oil change at a Jaguar dealer simply reflects the cost of doing business today. Almost everything is more expensive - labor, insurance, utilities, and the floor plan cost to carry inventory.
All that us DIYers are saying is that changing the oil and filter on a 5.0L JLR engine is one of the easiest things to do provided you have a good oil suction pump and the right filter wrench. You'll recover the cost of those tools after the first or second oil change, based on what you would have paid the dealer.
The following 5 users liked this post by Stuart S:
Barry Leftwich (06-06-2024),
bgpenguin21 (06-05-2024),
jahummer (06-10-2024),
OzXFR (06-05-2024),
ralphwg (06-09-2024)
#34
If you want to get into all the fine details on filters and oil I would ignore all of youtube? No way to tell what's good from bad as there is no barrier to posting wrong stuff. So you get a ton of it!
Take a look at Bob's The Oil Guy forum?
Bob's The Oil Guy
Post a question over there and get ready for a LOT of replies to your question!
Bob's The Oil Guy
#35
@Cee Jay is super fast, so let's assume it takes that Dealer's technician 30 minutes to do it. Both are 5.0L, and the dealer charges "close to 500 bucks". Let's say that the oil and filter cost $100, which leaves $400 for labor for 30 minutes work. That's at least $800 per hour!
But you get a free car wash! That's being taken to the (wallet) cleaners!
#36
Hey, don't yell at ME, Stuart quoted my post from the "What did you do today" thread, I wasn't even involved with this thread at that time.
#37
#38
I do my own oil changes. Not because I can’t afford to take it somewhere. And not because I’m cheap. I’ve been working on cars since I was a teenager, so, well, a lot of years… It’s partly because I want to be sure it’s done right, but more so because I can do the whole job in less time than it would take to just drive to a place and back. That’s not even counting the time to wait for the work to be done. So it’s a whole lot faster (and cheaper) to just do it in my garage.
Owner’s manual says 6000 miles. That seems like a good interval. New synthetic oil is supposed to be good for 15,000 or more. I don’t think it’s worth trying to push it that far. Oil and filters are cheap enough. Keep the oil fresh.
#39
Sure synthetic oil might last that long before breaking down BUT something else oil does besides lubricating is cleaning which's why the best interval's 5000 miles no matter how good the oil. By that point, the oil's loaded with carbon and other contaminates, frequent changing keeps the internals squeeky clean.
