A couple of "Is this normal" questions
Coming from an 03 XJR to 07 XKR I adore the car and just had a couple of questions.
1.When I come to a stop, sometimes I feel the car shift into first a few seconds after I stop. Is this normal?
2. When using the key fob from outside the car, if I hold unlock, the car unlocks and the windows roll down. When I hold lock, the car locks but the windows don't close. Is this normal?
Thanks!
Thanks!
1 - I used to feel the shift to 1st in an 07 XK. I think my current 08 XKR still does it - but it's less of a bump.
2- there's a menu somewhere in the touchscreen for things like drive away locking, 2 stage unlock, global open, and global close. Global open/close are what lets it open/close the windows from the keyfob. Check to see if global close is enabled. If it is you may need to reset the window memory.
My 08 has the same transmission abrupt "down shift" as I'm coming to a slooooow stop. I had the dealer look at it and they said all was normal. I'm not used to this (I'm a GM a guy). The car is driven very easy (I have a Z06 for play) so it's not the transmission trying to play sport on me.
Tom
Tom
WinterJag
16
10-09-2015 07:49 PM
