Creaking Sound When Braking.
Is it normal for the OEM brake pads to make the creaking noise when applying them at low speeds? I am planning on replacing them soon with ceramics due to the excessive dust and was hoping the creaking will be gone as well. My service advisor says the OEM pads do creak. Any feedback would be appreciated.
bocatrip (02-08-2014)
Yes it is a common issue. I had it on my 2007 XK until I renewed the pads all round with the Akebono ceramics. Greased up the caliper/pad contact points thoroughly using regular brake grease, tightened everything up and all is good. To be honest I did nothing special or use any special grease. A little TLC was all that was needed.
Steve
Steve
Steve
Steve
Glad to hear that the ceramics helped eliminate the creaking. Akebonos are not available for my fronts so I am going for Centric Posi Quiet Ceramics all around. I haven't bothered with the TSB hoping that just changing the pads would be the remedy.
Wait a mintues, where is it that we can purchase aftermarket Carbon Ceramic Brakes like the XKR-S GT has???
It was difficult enough finding Ceramics for fronts and rears on my 2010 XK which I found out is different than the 07-09 XKs. I'm not sure of availability for the limited production models. I have a feeling it might be a task to find them.
