Crickets in Air Vent
The chirping sound emanates from the blower motor on the passengers side. It probably got wet, due to the typical failure of the condensation of water in the airco.
I had the same problem, it disappeared after I changed the blower motor. Mind you, check first if there are signs of water on the passengers side. If you don't correct the blockage of the duckbill, your new motor is due to fail as well in time.
Pete Mantell
03-27-2016 10:28 PM
